2009 Dodge Ram 1500 4.7 engine ticking/knocking
Old Jan 8, 2020 | 11:53 PM
kboyd_82's Avatar
kboyd_82
Post 2009 Dodge Ram 1500 4.7 engine ticking/knocking
I have an 09 Dodge Ram 1500 with the 4.7 liter engine, It just hit 133k miles. It recently has developed a ticking/knocking noise coming from somewhere in the engine. It quiets down a little bit once engine is hot but never fully goes away. The check engine light is NOT on, I have good oil pressure, oil has been changed every 3k miles since ive had it, no loss of power. Ive always used synthetic blend oil in it. I took it to a local mechanic who I trust and have dealt with for years he listened to the noise and took it on a test drive, and he says its obviously not normal and thinks its coming from the valve train. He did say that whatever it is he will have to tear the engine down to confirm the problem, and more than likely it'll be a costly repair (which I figured). He is adamant it is not the exhaust manifold ticking. He actually told me that if it were his truck, he would just drive it until it got worse...... Anyway, what im here for is to ask if at 133k miles, is it a good idea to have it fixed? I know it is relatively low miles compared to some trucks still on the road, and I do have the means to get whatever is ticking/knocking fixed, but I would hate to have this issue fixed then something else major happen to it. Basically Im afraid this thing will turn into a money pit and dont want to just throw money at it if it wouldnt really be worth it in the long run. Any thoughts would be appreciated.
Old Jan 11, 2020 | 02:24 PM
Dodgevity's Avatar
Dodgevity
These engines can last a really long time. Mine is over 311K miles with nothing rebuilt and running smooth. I know you said you've been changing the oil, but how about checking it and topping off between oil changes? If the oil has habitually been run low, you may be dealing with a wear situation. If not, then have him pull the valve covers and see if something came loose. A tick is usually up top, a heavier knock is the main bearings below at which point, I'd just replace the engine.
Old Jan 13, 2020 | 11:57 PM
kboyd_82's Avatar
kboyd_82
It definitely sounds like its coming more from the bottom, the noise is slightly louder and more distinguished if you get under the truck...
Old Jan 19, 2020 | 07:36 PM
Secret Agent Man's Avatar
Secret Agent Man
Check the exhaust manifold or exhaust manifold gasket. My 09 5.7L developed a ticking noise and the exhaust manifold had a hairline crack in it. The lifetime powertrain warranty covered it.
