I Loose connection from computer to rest of pickup interment
Old Mar 22, 2020 | 06:08 PM
Jason Reitz's Avatar
Jason Reitz
Default I Loose connection from computer to rest of pickup interment
I loose my tach, speedometer, oil pressure, coolant. My lights come on for service 4wd, battery light, abs, check engine, brake control module and it goes crazy. I unhook all my battery cables for couple of hours and hook back up use my CTS clear codes and it works perfectly for a month or so and same thing happens. Any suggestions?
Old Mar 22, 2020 | 08:34 PM
primem's Avatar
primem
you would need to get the codes read to determine a starting point. sounds like a module losing communication.
Old Mar 23, 2020 | 04:58 PM
DodgeCares's Avatar
DodgeCares
Hi Jason, We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support.
Rob
DodgeCares
Old Mar 24, 2020 | 07:50 AM
SHO Rod's Avatar
SHO Rod
What year and model is your Ram? Have you recorded the diagnostic codes before disconnecting the battery and using the code reader or scan tool to clear them? If so, what codes are present? Does the truck continue to start and drive even when everything is wonky? Does the issue seem to be primarily limited to the instrument cluster?
-Rod
