2012 Cummins won't start
Old Apr 22, 2020 | 02:10 PM
Joseph Martin 1975's Avatar
Joseph Martin 1975
Default 2012 Cummins won't start
Just bought it Monday. I opened the door with a manual key that came with the truck and the alarm sounded. Didn't think anything of it but today it won't start. Has 12.6 in the batteries, says service 4wd comes up on dash? All seems like it should work but I think I made something go haywire with the alarm. Can't figure it out with all the tech. It's a Laramie and all electrical. It dose sound like it clicks the starter but never engages.help....
Old Apr 22, 2020 | 05:00 PM
Mike Holmen's Avatar
Mike Holmen
Are all the wires at the battery tight? There is a wire that uses a bolt that seems to loosen up. Have you locked/unlocked the truck since using the fob? You might have to clean the battery cables from corrosion. Mine gives me fits everyone and awhile as well..
Old Apr 22, 2020 | 05:07 PM
Joseph Martin 1975
They are tight. Has good voltage, checked 40 amp fuse for starter. I hear a click like the Bendix is engaging but not turning over. I assumed it was alarm related but I'm lost .
