Rear coil?!?!
Old Apr 30, 2020 | 01:38 PM
Nicholas Nolan's Avatar
Nicholas Nolan
Default Rear coil?!?!
I need help! I’ve searched far and wide and all through these forums and cannot seem to find information on the 4th gen rear coils.
First off , I have a 2015 1500, it is lifted , as per usual the kit came with spacers for the rear coils.
What I want to do , is replace that spacer block and just get longer coils.
I cannot for the life of me find REAR coils for the 1500 that are lifted .
I need coils that are 4” longer to replace the 4 inch block.
what I have found . Is that they make coils for the 2500 that are 3” longer
the 2500 coils naturally would raise the 1500 1-1.5 inch.
so the 3” coils would raise it 4-4.5 and be stiffer which would be ideal
HERE IS THE MILLION DOLLAR QUESTION!
Will the 2500 rear coil springs fit correctly on the 1500?!?!
Does it seat right on the top and bottom?!
Old May 2, 2020 | 07:35 PM
kayakman's Avatar
kayakman
Hi Nicholas, contact https://www.sdtrucksprings.com/
They might be able to help you or point you in the right direction
cheers
