Fog light wiring diagram for 2011 ram 1500
Old May 17, 2020 | 04:01 PM
Chris from France's Avatar
Chris from France
Smile Fog light wiring diagram for 2011 ram 1500
Hi everyone, I'm new here and and I just bought a 2011 ram 1500. I need to install fog light, and would find the wiring diagram of the factory fog light kit.like this :
82211694AB.
I already have the multi-switch.
Is Any body got this diagram or knows where I could find ? I don't know where to connect and what to the C3 connector.
Thanks, Chris.
Old May 17, 2020 | 04:33 PM
outlawstorm's Avatar
outlawstorm
I dont have a wireing diagram,, but the factory plug should be on drivers side front corner,,, ,, Mine it comes down at very front of the inner wheel liner and then T-s off to drivers light and then under rad to passengers side Usually all the main wiring is already in most of these trucks
Old May 18, 2020 | 04:50 PM
Chris from France
Thanks for your answer. In the kit there is 2 wires. they go to the fog lamp and the other side it must be connected to a connector by pins. This side interest me to finalise my installation.
And another thing I would know. Can I activat the fog with a obd reader ? Or what obd I need if it's possible ?
Here in France the rear fog is an obligation. This is why I searching for this diagram to help me to instal this fog lamp. If you can post some photos about connections ?
Old May 23, 2020 | 08:28 AM
Chris from France
This is what I looked for :
If somebody need complete installation instructions pdf. I can share it.
Old Jun 1, 2020 | 08:19 AM
tigo2018's Avatar
tigo2018
Hello Chris,
I don't think you're able to activate fog or anything else with an OBD2 scanner,it is a default codes reader.
An easier and safer option would be to install and run your fog light from a power source,switch,fuse and relay aside from your truck system .
I have a 2002/2009 complet service manual with electrical diagrams that could help you out with your problem,2009 should be pretty close to your 2011 , let me know if you want me to send it out to you.
tigo2018
Old Jun 7, 2020 | 03:50 PM
Chris from France
...dispointed here, In France Dealers are anable to activate fog option with their computer. So I let it down. Here it's FIAT who is owners of Chrysler Jeep Dodge. And they can do nothing for me to activate those fog light. I call Luxemburg and it's the same. Either can do nothing. I'll drill dashboard and add a switch.Thanks for your answers.
Old Sep 30, 2022 | 11:21 PM
bman0279's Avatar
bman0279
the alphaobd app can turn them on. You will need a Bluetooth obd 2 interface like the elm 327
