2017 Ram 1500, 5.7L Pickup won't crank.
Old Nov 14, 2021 | 10:39 AM
GlitchMobile's Avatar
GlitchMobile
Question 2017 Ram 1500, 5.7L Pickup won't crank.
2017 Ram 1500, 5.7L
Pickup won't crank.
I have a blinking red light on the dashboard display and the radio displays
"Anti theft Code, Code error: Please restart the system"
How do I enter the code, or am I at the mercy of the dealer?
Old Nov 14, 2021 | 12:55 PM
Try using your key to manually unlock the drivers door twice.
Old Nov 17, 2021 | 12:11 AM
GlitchMobile
Hi, thanks for the suggestion. I was so hopeful to get the car to work, that I went out right away to try it out. Unfortunately
it didn't work.
Old Nov 17, 2021 | 06:26 PM
Pedro Dog's Avatar
Pedro Dog
Anti theft is active. Give us more details. Was the truck starting before? does it have an aftermarket alarm? Have you tried a different fob? Have you tried disconnecting the battery?
Old Nov 18, 2021 | 07:43 PM
GlitchMobile
Yes, the truck did start at least five times and then it stopped starting.
No aftermarket alarm.
I tried the 2nd key fob and had the same results, no start.
I've tried disconnecting the battery several times for periods of over 24hrs. Truck still dead.
I checked the CanBus and its at 61ohms. The 5v reference line is active.
I think the PCM is dead. So I've sent it out for reflashing.
