Is the 4.7 engine block the same from the pre 2008 models as the post 2008 models?
Old Dec 28, 2021 | 11:05 AM
Barnstorm's Avatar
Barnstorm
Default Is the 4.7 engine block the same from the pre 2008 models as the post 2008 models?
Hi folks. I’m new here and I’m wondering if I can use an older 4.7 engine block with the newer heads and intake on a 2012 Dodge ram 1500. The reason is I’m having a hard time finding a fourth gen ram in a wrecking yard these days. However there are lots of older ones. I bought the truck with the seized engine pulled it apart and found that the bottom end was locked up but the heads look fine. Any help would be appreciated thanks in advance.
