Break lights stay on in run
Old May 23, 2022 | 04:38 PM
dodge help 101's Avatar
dodge help 101
Default Break lights stay on in run
I have a 2010 Dodge Ram 1500 4.7 The issue is when the truck is in the start position or on position my brake lights stay permanently on like I’m on my break pedal I have replace the brake switch a couple times I’ve replaced lights I have it up and down for about six months trying to figure this out I need some help if anybody else out there knows what I can do to fix this issue
Old May 24, 2022 | 12:47 AM
SHO Rod's Avatar
SHO Rod
Welcome to the forum!
Does the Center High Mount Stop Lamp also remain on, or only the brake lights in the tail light housings? Do you have a trailer you could connect to see if the trailer brake lights remain on as well?
The brake lights are controlled by the Totally Integrated Power Module (TIPM) based on two brake signal inputs. Do you have a multimeter to be able to test the TIPM inputs and outputs? They may not be too easy to get to.
-Rod
