Need help !
Old Jun 14, 2022 | 10:12 AM
Jlmorgan87's Avatar
Jlmorgan87
Default Need help !
2015 dodge outdoorsman cruise control shuts off randomly 4-5 times around 75 mph on hr and half trip every morn and feels like front driver brake locking up tcs flashes then after few secs everything goes back to normal
Old Jun 16, 2022 | 11:26 AM
SHO Rod's Avatar
SHO Rod
If you make the same drive to the best of your abilities without the cruise control on do you get the same sensation of the front driver brake locking up? It sounds like it could be a wheel speed sensor or tone ring issue. But if the brake is being applied to the right front wheel, I'd almost expect the sensor/tone ring issue to be on a different wheel, causing the ABS/TCS system to think the right front is the wheel with traction. I imagine if you had access to a scan tool that can access the ABS system you'd have already looked for ABS codes and monitored the datastream of the wheel speed sensors, right?
-Rod
