Where is the TPMS button…
What do you mean by a TPMS button? Are you trying to activate new sensors, or update after a tire rotation, or something else? I don't think there is a TPMS button, I think programming new sensors requires a scan tool with TPMS feature and an activation tool.
-Rod
-Rod
You'll most likely need to remedy the sensor/pressure issue before the light will go out. I'm not aware of any button you can press to extinguish the TPMS warning light. Your best bet may be to find someone with a TPMS activation tool to see if the three sensors in question are working and if the batteries are good to determine if this is a sensor issue or a TPMS receiver/system issue. You could also try pulling the fuse for the TPMS system (I think it's the Wireless Ignition Node) for a bit in an attempt to reset it.
-Rod
-Rod
