09 RAM 1500 WIN module and TPS codes... HELP!!!
Old May 24, 2023 | 10:18 PM
OH_zach_IO's Avatar
OH_zach_IO
Default 09 RAM 1500 WIN module and TPS codes... HELP!!!
I have a 5.7 hemi 1500 issues started with, no crank/no start, dash told me "damaged key" and "key in ignition" when they weren't in the truck. After alot of trouble shooting and sensors being hooked to it. I figure it's a WIN module. After replacing the ignition, It would start and slowly idle up and shut off as though I turned the key off. Now the check engine light and red lightning bolt lights are on and codes P2115, P2116, P2166, & P2167 are showing up. I've replaced the APPS and the issue has gone back to no crank/no start but now with the check engine and red lightning bolt lights flashing.
Sorry for rambling... I'm flustered as all get out!
