Upper Intake Manifold Torque Specifications
Old Jun 9, 2023 | 11:19 AM
dnl's Avatar
dnl
Default Upper Intake Manifold Torque Specifications
Getting time to replace my spark plugs on my 2015 Ram Truck, 3.6L V6.
I understand I need to remove the intake manifold. What are the bolt torque specs?
Thanks
Old Jun 11, 2023 | 08:47 AM
SHO Rod's Avatar
SHO Rod
Assuming the 2015 is the same as the 2014, the upper intake manifold M6 bolt torque is 89 in-lbs and the lower manifold M6 bolt torque is 106 in-lbs.
-Rod
Old Jun 11, 2023 | 05:04 PM
dnl's Avatar
dnl
thanks. I had seen 7-8ft/lbs, and wanted to double check.
