Are You Getting the Correct Bulbs for Your 2009-2012 Dodge Ram 1500/2500/3500?
Old Aug 21, 2023 | 10:22 PM
LASFIT's Avatar
LASFIT
Former Vendor
Default Are You Getting the Correct Bulbs for Your 2009-2012 Dodge Ram 1500/2500/3500?
Headlight Type For 2009-2012 Dodge Ram 1500/2500/3500
There are 2 types of forward lighting bulbs for 2009-2012 Dodge Ram 1500/2500/3500, 2-housing type and 4-housing type.
Which is right for your car?
Here are some tips from Lasfit, professional sellers, who aim to provide high-quality service to their customers.
Type 1: 4 lights in 2009-2012 Dodge Ram 1500/2500/3500 headlight housing
If your Ram has 4 lights (as in the below picture), then the high beam and low beam are separate bulbs. The high beam bulb size is 9005, and the low beam bulb size is H11.
Type 2: 2 lights in 2009-2012 Dodge Ram 1500/2500/3500 headlight housing
If your Ram has only 2 lights (refer to the below picture), which means low beam and high beam share the same bulb, the correct bulb size is H13.
LED Bulbs Recommendation For 2009-2012 Dodge Ram 1500/2500/3500 (Click to Order)
9005 LED bulbs (fit 2009-2012 Dodge Ram 1500/2500/3500 with 4 lights)http://www.lasfit.com/collections/90...beam-la-series
H11 LED bulbs (fit 2009-2012 Dodge Ram 1500/2500/3500 with 4 lights)http://www.lasfit.com/collections/h1...ight-la-series
H13 LED bulbs (fit 2009-2012 Dodge Ram 1500/2500/3500 with 2 lights)http://www.lasfit.com/collections/h1...beam-la-series
Wrong Purchase Example
We have 2 customers who bought the wrong led light bulbs.
1. Greg bought a set of H13 LED bulbs for his 2011 Dodge Ram 1500, but later he reported that the LED bulbs were wrong.
Because his truck is the 4-housing type, the high beam bulb size is 9005, and the low beam is H11.
2. David purchased a set of H11 LED lights and tried to install them on his 2009 Dodge Ram 2500, but he was very disappointed when they didn’t fit his pickup.
Actually, his truck is the 2-lighting type, so his truck bulbs are H13.
If you’re still not sure about your truck bulb size, please leave a message on this post.
