2013-2015 Ram 1500 LED Upgrade Bulb Size Guide
Old Sep 4, 2023 | 10:29 PM
LASFIT's Avatar
LASFIT
Former Vendor
Default 2013-2015 Ram 1500 LED Upgrade Bulb Size Guide
Upgrade your 2013-2015 Ram 1500 with Lasfit LED bulbs for a brighter and clearer lighting experience. Say goodbye to dim, yellow factory lights that may hinder your visibility on dark roads. With Lasfit, you can explore a wide range of compatible LED bulbs specifically designed for your Ram 1500.
In our previous post, we discussed the LED bulbs for the 2016-2023 Ram 1500. However, we haven't forgotten about the owners of 2013-2015 Ram 1500. With the LAplus series, you can easily find suitable options for your low beam and high beam, fog, backup, cargo, 3rd brake, and license plate lights, as well as map and glove box lights to illuminate the interior of your vehicle.
Enhance your driving experience and ensure optimal visibility with Lasfit LED bulbs. Upgrade your 2013-2015 Ram 1500 today and enjoy the benefits of a brighter and more efficient lighting system.
You can check all compatible LED bulbs for 2013-2015 Ram 1500 from this page:http://www.lasfit.com/products/led-b...-2015-ram-1500
Product Spec for 2013-2015 Ram 1500
Low Beam: LAplus H11/LAplus 9012
LAplus H11 for Ram 1500 with reflector
LAplus 9012 for Ram 1500 with projector
High Beam: LAplus 9005
Each bulb in the LAplus H11 or 9012 series is meticulously engineered to deliver a robust 30W and 3000LM output, resulting in a remarkable brightness for your headlights compared to conventional halogen bulbs. These bulbs are specifically tailored to suit your 2013-2015 Ram 1500. With their radiant 6000K bright white light, you can enjoy exceptional visibility on even the darkest roads. The 360-degree adjustable socket allows for effortless customization of the beam pattern, ensuring optimal lighting performance according to your preferences. Furthermore, these bulbs are equipped with an interior driver and smaller sizes can't prevent you from inserting these LED bulbs into the housing.
(Lasfit LAplus H11 LED bulbs for Ram 1500 with reflector)
(Lasfit LAplus 9012 LED bulbs for Ram 1500 with projector)
(Lasfit LAplus 9005 LED bulb for high beam)
Fog Lights: LAplus H10/LAplus 9006
LAplus H10 for Ram 1500 with reflector
LAplus 9006 for Ram 1500 with projector
LAplus fog lights offer 60W power and an ultra-high brightness of 6000LM. Its 6000K white light effectively penetrates rain, fog, and snow, allowing for clear visibility of road conditions in adverse weather. With no extra driver required, installation on the fog light housing is hassle-free. Additionally, the 360° adjustable booth ensures easy installation on the fog light housing.
Please don't worry about the dim light of the original car will make you lose your direction, LAplus is definitely your best choice to replace the Ram 1500 fog lights.
(Lasfit LAplus H10 for Ram 1500 with reflector)
(Lasfit LAplus 9006 for Ram 1500 with projector)
Rear Exterior LED Lights
Backup lights: L-7443/L-T15
L-T15 for Ram 1500 with reflector
L-7443 for Ram 1500 with projector
L-T15 LED bulbs equipped with high-power 3030 SMD LED chips, each bulb can provide 700LM and 6000K pure white can let the rear vehicle notice you are reversing.
The L-7443 can have 6000K bright white, It is capable of providing 1200LM/set for the Ram 1500 with a projector and adds additional visibility to the rear of the vehicle when backing up.
(Lasfit L-T15 for Ram 1500 with reflector)
(Lasfit L-7443 for Ram 1500 with projector)
Cargo Lights: L-T15
3rd Brake Lights: L-T15R(Red)
The Lasfit L-T15 bulb is designed to provide a bright output of 1400LM per set, ensuring sufficient brightness to alert vehicles behind you. Moreover, you can rest assured about compatibility issues as it is canbus supported, reducing the hassle of flickering lights.
(Lasfit L-T15 for cargo lights)
(Lasfit L-T15R for 3rd brake lights)
License Plate Lights: L-T10
The L-T10 series features 3 bright 3030 lamp beads that can provide 800LM of brightness for the 2013-2015 Ram 1500. With its 6000K white light, it can effectively illuminate the rear license plate, ensuring clear visibility. The 360° lighting effect ensures that no area is left in darkness, providing ample lighting for vehicles approaching from the rear.
Interior LED Lights
Glove Box Lights: L-T10
The L-T10 interior light from Lasfit is a versatile option that can be installed in various locations on different vehicles. For the 2013-2015 Ram 1500, it can be installed as a glove box lights. The L-T10 features a non-polarity design for easy plug-and-play installation, ensuring an error-free experience. With a configuration of 800LM per set, it provides superior brightness compared to the original halogen bulbs.
Additionally, the L-T10 series offers a range of color options, including white, yellow, blue, and green, allowing you to customize your glove box lights according to your preferences and needs.
Map Lights: L-44MM
The L-44MM festoon bulb from Lasfit is equipped with 8 3030 SMD LED chips, providing an extremely bright 6000K white light. It features an Efficient Aluminum Heatsink System, which enables the Ram 1500 to dissipate heat effectively, thereby extending the lifespan of the headlights.
Moreover, You Can Get..
● 45 Days Money-Back Guarantee
Our return policy allows you to return your purchase within 45 days of the date of purchase for a full refund, no questions asked. We make the return process hassle-free by providing a return shipping label for your convenience.​
● 1-Year Hassle-Free Warranty
Lasfit provides a hassle-free return policy and warranty for 1 year. In the event of any quality issues, we offer an easy exchange or return with a provided return label.
If you have any questions about the mentioned information, please leave a message in this forum.
