2013-2015 Ram 1500 LED Upgrade Bulb Size Guide
Old Dec 5, 2023 | 09:18 PM
LASFIT's Avatar
LASFIT
Former Vendor
Default 2013-2015 Ram 1500 LED Upgrade Bulb Size Guide
Are you still worried about encountering deer suddenly darting across the road during nighttime driving? Or perhaps dim factory lights making it challenging to see the road clearly at night? No need to worry—Lasfit offers a comprehensive range of LED bulbs tailored for your Ram 1500 lighting upgrade. Whether you have headlights with projectors or reflectors, you can enjoy brighter and perfectly aligned high and low beams. Additionally, the pure white fog lights ensure optimal visibility on rainy, snowy, or foggy days.
In addition to upgrading headlight bulbs and fog lights, Lasfit also provides a new and improved 3157 LED bulb for your tail lights, offering a brilliant red glow to make your pickup clearly visible to those behind you when changing lanes or braking.
For components like the 3rd brake lights, license plate lights, cargo lights, and certain interior lights, Lasfit offers corresponding LED bulb upgrade options. Follow along as we introduce you to a more comprehensive understanding of what Lasfit provides LED bulb upgrades for 2013-2015 Ram 1500 owners.
Product Spec for 2013-2015 Ram 1500
Low Beam: LAplus H11/9012
LAplus H11 for Ram 1500 with reflector
LAplus 9012 for Ram 1500 with projector
High Beam: LAplus 9005
Each bulb in the LAplus H11 or 9012 series is meticulously engineered to deliver a robust 30W and 3000LM output, resulting in a remarkable brightness for your headlights compared to conventional halogen bulbs. These bulbs are specifically tailored to suit your 2013-2015 Ram 1500. With their radiant 6000K bright white light, you can enjoy exceptional visibility on even the darkest roads. The 360 degree adjustable socket allows for effortless customization of the beam pattern, ensuring optimal lighting performance according to your preferences. Furthermore, these bulbs are equipped with an interior driver and smaller size can't prevent you insert these LED bulbs into the housing.
LAplus H11 LED bulbs for Ram 1500 with reflector
LAplus 9012 LED bulbs for Ram 1500 with projector
LAplus 9005 LED bulbs for Ram 1500 high beam
Fog Lights: LAplusH10/9006
LAplus H10 for Ram 1500 with reflector
LAplus 9006 for Ram 1500 with projector
LAplus fog lights offer 60W power and an ultra-high brightness of 6000LM. Its 6000K white light effectively penetrates rain, fog, and snow, allowing for clear visibility of road conditions in adverse weather. With no extra driver required, installation on the fog light housing is hassle-free. Additionally, the 360° adjustable booth ensures easy installation on the fog light housing.
Please don't worry about the dim light of the original car will make you lose your direction, LAplus is definitely your best choice to replace the Ram 1500 fog lights.
LAplus 9006 LED bulbs for Ram 1500 with projector
LAplus H10 LED bulbs for Ram 1500 with reflector
Rear Exterior LED Lights
Rear Turn Signal/Brake/Tail Lights: T3-3157R
We have new rear turn signal/brake/tail lights available for the Ram 1500. These lights have a power output of 24W and a brightness level of 2000LM, ensuring that anyone behind you can clearly see when you are braking or changing lanes. Additionally, these lights are equipped with a built-in micro decoder and an upgraded cooling system, making them stand out in terms of design and functionality.
Backup Lights: L-7443/L-T15
L-T15 for Ram 1500 with reflector
L-7443 for Ram 1500 with projector
L-T15 LED bulbs equipped with high-power 3030 SMD LED chips, each bulb can provide 700LM and 6000K pure white can let the rear vehicle notice you are reversing.
The L-7443 can have 6000K bright white, It is capable of providing 1200LM/set for the Ram 1500 with a projector and adds additional visibility to the rear of the vehicle when backing up.
Cargo Lights: L-T15
3rd Brake Lights: L-T15R(Red)
The Lasfit L-T15 bulb is designed to provide a bright output of 1400LM per set, ensuring sufficient brightness to alert vehicles behind you. Moreover, you can rest assured about compatibility issues as it is canbus supported, reducing the hassle of flickering lights.
License Plate Lights: L-T10
The L-T10 series features 3 bright 3030 lamp beads that can provide 800LM of brightness for the 2013-2015 Ram 1500. With its 6000K white light, it can effectively illuminate the rear license plate, ensuring clear visibility. The 360° lighting effect ensures that no area is left in darkness, providing ample lighting for vehicles approaching from the rear.
Interior LED Lights
Glove Box lights: L-T10
The L-T10 interior light from Lasfit is a versatile option that can be installed in various locations on different vehicles. For the 2013-2015 Ram 1500, it can be installed as a glove box lights. The L-T10 features a non-polarity design for easy plug-and-play installation, ensuring an error-free experience. With a configuration of 800LM per set, it provides superior brightness compared to the original halogen bulbs.
Additionally, the L-T10 series offers a range of color options, including white, yellow, blue, and green, allowing you to customize your glove box lights according to your preferences and needs.
Map Lights: L-44MM
The L-44MM festoon bulb from Lasfit is equipped with 8 3030 SMD LED chips, providing an extremely bright 6000K white light. It features an Efficient Aluminum Heatsink System, which enables the Ram 1500 to dissipate heat effectively, thereby extending the lifespan of the headlights.
Customer Feedback
*The following contents are authorized by our customers, many thanks to them!
Case1
I ordered the whole kit for my truck and the low beam lights didn’t quite fit in the housing. I contacted the seller and they sent a different set right out to me. Those were snug in the housing but they did fit in there and work fine. The quality of the bulbs and packaging and the customer service was great.---B.B.(2015 Ram 1500)
If you have any questions about the mentioned information, please leave a message in this forum.
