2016-2018 Ram 1500 LED Upgrade Bulb Size Guide
Old Dec 20, 2023 | 01:24 AM
LASFIT's Avatar
LASFIT
Former Vendor
Default 2016-2018 Ram 1500 LED Upgrade Bulb Size Guide
Do you still worry about the dim yellow light from your factory halogen bulbs hindering your visibility on dark roads at night? Are you concerned about the short lifespan of the halogen lights, requiring frequent replacements? No need to worry anymore! Allow us to introduce the 2016-2018 Ram 1500 lights replacement guide.
Owners of the 2016-2018 Ram 1500 can still find suitable bright, regular, and fog light options to replace their halogen bulbs with LAplus. When it comes to exterior lighting, we offer not only backup lights, cargo lights, and 3rd brake lights, but also license plate lights. For interior lighting, we provide users with map lights and glove box lights.
Product Spec for 2016-2018 Ram 1500
Low Beam: LAplus H11/9005
LAplus H11 for Ram 1500 with reflector
LAplus 9005 for Ram 1500 with projector
High Beam: LAplus 9005
Each bulb in the LAplus H11 or 9005 series is meticulously engineered to deliver a robust 30W and 3000LM output, resulting in a remarkable increase in brightness compared to conventional halogen bulbs. These bulbs are specifically tailored to suit your 2016-2018 Ram 1500. With their radiant 6000K bright white light, you can enjoy exceptional visibility on even the darkest roads. The 360-degree adjustable socket allows you to adjust the beam pattern to perfect.
Fog Lights: LAplus H11/9006
LAplus H10 for Ram 1500 with reflector
LAplus 9006 for Ram 1500 with projector
LAplus fog lights offer 60W power and an ultra-high brightness of 6000LM. Its 6000K white light effectively penetrates rain, fog, and snow, allowing for clear visibility of road conditions in adverse weather. With no extra driver required, installation on the fog light housing is hassle-free. Additionally, the 360° adjustable booth ensures easy installation on the fog light housing.
Please don't worry about the dim light of the original car will make you lose your direction, LAplus is definitely your best choice to replace the Ram 1500 fog lights.
Rear Exterior LED Lights
Rear Turn Signal/Brake/Tail Lights: T3-3157R
We have new rear turn signal/brake/tail lights available for the Ram 1500. These lights have a power output of 24W and a brightness level of 2000LM, ensuring that anyone behind you can clearly see when you are braking or changing lanes. Additionally, these lights are equipped with a built-in micro decoder and an upgraded cooling system, making them stand out in terms of design and functionality.
Backup Lights: L-7443
The L-7443 can have 6000K bright white, It is capable of providing 1200LM/set for the 2016-2018 Ram 1500 and adds additional visibility to the rear of the vehicle when backing up.
Cargo Lights: L-T15
3rd Brake Lights: L-T15(Red)
The Lasfit T15 bulb is designed to provide a bright output of 1400LM per set, ensuring sufficient brightness to alert vehicles behind you. Moreover, you can rest assured about Compatibility issues as it is canbus supported, reducing the hassle of flickering lights.
License Plate Lights: L-T10
The L-T10 series features 3 bright 3030 lamp beads that can provide 800LM of brightness for the 2016-2018 Ram 1500. With its 6000K white light, it can effectively illuminate the rear license plate, ensuring clear visibility. The 360° lighting effect ensures that no area is left in darkness, providing ample lighting for vehicles approaching from the rear.
Interior LED Lights
glove box lights: L-T10
The L-T10 interior light from Lasfit is a versatile option that can be installed in various locations on different vehicles. For the 2016-2018 Ram 1500, it can be installed as a glove box lights. The L-T10 features a non-polarity design for easy plug-and-play installation, ensuring an error-free experience. With a configuration of 800LM per set, it provides superior brightness compared to the original halogen bulbs.
Additionally, the L-T10 series offers a range of color options, including white, yellow, blue, and green, allowing you to customize your glove box lights according to your preferences and needs.
Map Lights: L-44MM
The L-44MM festoon bulb from Lasfit is equipped with eight 3030 SMD LED chips, providing an extremely bright 6000K white light. It features an Efficient Aluminum Heatsink System, which enables the LED bulbs to dissipate heat effectively, thereby extending the lifespan of the lights.
Customer Feedback
*The following contents are authorized by our customers, many thanks to them!
Case1
I purchased all new bulbs for up front (hi/lo-beam and fogs) got the headlights in and they work flawlessly fogs were incorrect (could have been my error) but the customer service really came through and had the correct set on their way before I even shipped out the old ones. 100% happy in the end.---Jacob ***(2016 Ram 1500 Laramie)
Case2
I had ordered some led lights. however, my one of my lights went out dim and figured I would contact lasfit customer serve center to see if I could get a replacement rather than purchasing a new set of lights. they went ahead and sent me a new set of my lights and shipped it next day. Great customer service and lights worked great.---Khalil Awad
Case3
All I can say is...wow!
Thoroughly impressed not only with the product but with the service.
I was sceptical at first, how could LEDs at this price point be any good? I figured I would try it, and return it if it didn't work out. Not only did the bulbs arrive on time (nicely packed by the way), the build quality of each bulb was impressive.
I ordered the entire kit to swap all my bulbs to LED on my 2018 Ram 1500. I was worried my computer was going to throw codes and that I'd need AlphaOBD to program my system. I had ZERO issues. It was literally plug-in-play. I didn't have to reprogram anything.
One last thing, their customer service is excellent. I believe I ordered the wrong kit because I ended getting different bulbs for my fog lights than I was expecting. Called them up, had it shipped to me right away for free.
I DEFINITELY would recommend these bulbs to anyone.---M.E.
Act now and discover the perfect socket solution for a seamless LED bulb upgrade!
Old Dec 26, 2023 | 04:19 PM
William Scott's Avatar
William Scott
Thanks for sharing
Old Dec 27, 2023 | 04:42 AM
LASFIT's Avatar
LASFIT
Former Vendor
Originally Posted by William Scott
Thanks for sharing
Thank you very much for liking this thread! I would like to ask if you have any need to replace LED bulbs? If so, please let me know and I will provide you with suitable lights.
