MDS/VVT system issue
Old May 25, 2024 | 04:54 PM
jimchappell50's Avatar
jimchappell50
Default MDS/VVT system issue
2009 Ram 1500 5.7L 2wd TRX 283k
My manifold cover bolts were loose and I did not realize it for a long time. By the time that I figured it out, the front corner by cylinder 1 had melted a bit I fixed that with JB Weld.
Oil had gotten to the jumper harness that wires the MDS/VVT system together and it destroyed a good bit of insulation on the harness. I can see bare conductors everywhere. I am sure that there are areas of the harness that are damaged that I just can't see given the way that the wires are all run together.
I tried to repair some of it with electrical tape but it is still acting up. The harness, part # 4801719AB, is discontinued. I ordered one off of amazon for a 2010 ram but the connectors for the 4 crankshaft position sensors do not fit the sensors.
Does anyone know if I can cut off the connectors from the new harness and pigtail the old ones on and have it work properly?
Or, if I buy 4 crankshaft position sensors for a 2010 ram, will they fit my 2009 and can I then just use this harness?
Not sure what to do here as it is slowly becoming oblsolete.
Any help or ideas would be appreciated.
Old May 28, 2024 | 10:18 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Are you confusing the MDS solenoids for something else? There is only ONE crank sensor and only ONE cam sensor.
