2010 dodge ram 4.7l trx4 issues
Old Aug 5, 2024 | 09:22 PM
Rougeguacamole's Avatar
Rougeguacamole
Default 2010 dodge ram 4.7l trx4 issues
So I replaced my timing chains and tentioners everything was fine for 3 days then my truck shut off thru a code for bank 1 sensor 1, bank 2 sensor 1 ,cam position sensor and crankshaft position sensor I replaced bothe cam and crank as I was dead in the middle of the road truck will idle for a while then shut off. I opened the valve covers and checked timing and everything is in time. Is it possible for a bad 02 sensor(s) to cause this issue I am replacing all 4 anyways I just don't want to open the front end again if I don't need to. Any help would e appreciated
