2015 Ram 3500 6.4 Coolant temp and throttle sensor codes
Old Jan 27, 2025 | 08:27 AM
LeeRoy42's Avatar
LeeRoy42
Default 2015 Ram 3500 6.4 Coolant temp and throttle sensor codes
I have (2) codes that came on at the same time, P2181 and P2110, cooling system and electronic throttle control, has anyone had this issue and what was done to fix it?
Old Jan 27, 2025 | 08:47 AM
dodgetruck2's Avatar
dodgetruck2
If both codes are active I would try unplugging them individually and see if the other fault goes away. If one of them is potentially causing a supply voltage issue causing other issues
Old Jan 27, 2025 | 09:31 AM
dodgetruck2
EDIT: double post
Old Jan 28, 2025 | 08:44 AM
LeeRoy42's Avatar
LeeRoy42
I changed out the thermostat yesterday and all of my gauges are back to normal, after a long drive I will know if the failing t-stat temp sending unit was the issue or not.
