Puddle light connector not the same
Old Nov 7, 2025 | 08:26 AM
BlueBeast2's Avatar
BlueBeast2
Default Puddle light connector not the same
Has anyone else ran into this?
Got some new puddle lights for my 15 Ram and the passenger side connector is different than the drivers side. I assume the mirror was swapped out at some point. I believe the carfax said there was drivers side damage in the past but other than some minor bumper damage everything looked normal
Edit: well after popping the blind spot mirror off (got new turn signal lights as well) that plug is different as well
Old Nov 10, 2025 | 11:56 AM
sgmldr's Avatar
sgmldr
Default Yep, that happened
I had the exact same issue with my 2010. The mirror assembly is an aftermarket replacement. I ended up just reworking the wiring to make it work and sealed with silicone caulk.
