How to Install the 9005 LED High Beam Bulbs on 2019-2021 Ram 1500 Bighorn
Are you tired of struggling with dim high beams during nighttime drives, leaving you squinting to see the road ahead? Fear not—Lasfit has the perfect solution with its LED bulb upgrade! But wait, there's more! In this post, we'll take you on an illuminating journey, showing you how to easily swap out your factory halogen bulbs yourself. Plus, you'll witness firsthand the striking difference in brightness between Lasfit LED bulbs and traditional halogens. Join us as we shed light on how to upgrade your Ram's high beams and illuminate the road like never before!
High Beam Bulb for 2019-2021 Ram 1500 with reflector headlight: LAplus 9005
(Stock halogen bulb size: 9005)
30W, 3000LM, pure white, delivering a high-intensity lighting experience; with a 360-degree socket, allowing you to adjust the beam pattern to perfect; upgraded cooling system and strong fan effectively dissipate heat generated during work; simple installation steps and non-polarity design enable plug-and-play convenience.
How to Install the High Beam Bulb
Step1
Open up the hood latch, and find out the location of the high beam bulb
Step2
Remove the dust cap, and take the factory bulb off the headlight housing
Step3
Disconnect the Factory halogen bulb, and take the bulb off
Step4
Put the LED bulb into the housing, and connect with the power charge
Step5
Test if the bulb works
Step6
Put the dust cap back, and close the hood
Installation Tips:
1. Before installing LED bulbs, we recommend wearing a pair of gloves to prevent static electricity!
2. You can choose to open the hood or access the engine space from the tire fender to replace the headlight.
3. Please ensure that the bulb is oriented with the 3-9 o'clock positions, while the wire points downward at the 6 o'clock position.
Brightness showcase
LAplus 9005 LED Bulb compare with the halogen bulb
LAplus 9005 LED Bulb brightness
Isn't installing a 9005 LED bulb supposed to be a piece of cake? It's all about getting your hands dirty and swiftly swapping it out yourself! No need to rely on others or fork out extra cash for help! Dive into the world of the 9005 LED bulb—it's bound to impress and revolutionize your nighttime driving experience!
You can also learn more about how to install 9005 LED high-beam bulbs on the Ram by watching the video below.
But wait, there's more! Lasfit is currently offering a special discount for the LAplus series—order now and enjoy a whopping 25% OFF! Limited to the first 200 customers only! Don't let this opportunity slip through your fingers! The offer ends on April 28th, so act fast and don't miss out!
