Notices
MOPAR HARMONIC FLUID DAMPER
Old Jun 9, 2007 | 01:54 PM
Belfab Racing Produc's Avatar
Default MOPAR HARMONIC FLUID DAMPER
MOPAR HARMONIC FLUID DAMPER $82.50
S.F.I. RACING FLUID DAMPER
One Year limited Warranty...High Quality
Mopar 239 / 318 / 340 / 373 1964 - 1991
You are looking at a New Mopar Racing Fluid Damper, 7-1/4" OD, Black Anodized finish.
Mopar fluid dampers are manufactured from forged 1025 low carbon steel housing and injected with high viscosity silicone fluid.
A nylon ring and nylon position guides allow the steel inertia ring a rotation freely inside the housing.
The steel inertia ring rotates harmonically with the engine and absorbs the torsion vibration from the rotating assembly at any frequency and RPM. It thus extends the life of crankshaft and bearing and allows the engine to produce more power and torque.
All dampers are tested to 12,500 RPM forexplosion proof in compliance with SFI 18.1 Specification
all dampers are designed for press fit to crank
This is for the racers primarily looking for the lightest rotating weight they can get for an internally balanced Mopar V8
[IMG]local://upfiles/64900/D9E1820FC6704BA09565C91451551470.jpg[/IMG]
Old Jun 13, 2007 | 01:08 AM
lilhemi's Avatar
lilhemi
Default RE: MOPAR HARMONIC FLUID DAMPER
How about for a 5.7 ?
Old Jun 13, 2007 | 05:22 PM
00r/t's Avatar
00r/t
Do you have one of these to fit a 2000 dodge Dakota R/T 5.9L? I believe the harmonic balancer & pully are a 1 piece unit.
