Notices
Brembo Drilled Rotors
Old Aug 31, 2007 | 02:06 PM
sstgonzo's Avatar
sstgonzo
Default RE: Brembo Drilled Rotors
Im not sure how they are different....to be honest?
Old Aug 31, 2007 | 02:56 PM
ICEMAN_CH's Avatar
ICEMAN_CH
From what I understand on a 2wd the hub and rotor are one peice. The 4wd they are 2 peices. The easiest way to check is to pull off your tire. If the bolts for your tire go through the rotor then its two peices. If the bolts are pushed into your rotor the they are one peice. I know this isn't a very good explanation.
Old Sep 8, 2007 | 04:34 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Do the bump yay
Make an offer someone.
Old Oct 24, 2007 | 05:10 PM
donnypd's Avatar
donnypd
if they fit a 97 4wd would you take 55 shipped? to 24013. thanks.
p.s. they come with pads correct?
