Notices
wtb!! e85 flex fuel conversion!
Old Oct 29, 2007 | 06:07 PM
sprtsfrk's Avatar
sprtsfrk
Member
Default wtb!! e85 flex fuel conversion!
I want to buy the full flex gold e85 conversion kit for a v6 dakota. if anyone has it and wants to get rid of it please email sprtsfrk1569@tmail.com with a price. thanks!I want to buy the full flex gold e85 conversion kit for a v6 dakota. if anyone has it and wants to get rid of it please email sprtsfrk1569@tmail.com with a price. thanks!
Old Dec 17, 2007 | 12:29 PM
Nofrag's Avatar
Nofrag
Default RE: wtb!! e85 flex fuel conversion!
It's worth buying new, http://www.change2e85.com/servlet/Pa...plate=chrysler
Old Dec 18, 2007 | 01:17 PM
stratusguy02's Avatar
stratusguy02
ORIGINAL: Nofrag
I wouldn't put that on your car if you value your injectors, fuel line seals and fuel pump. The E85 will chew through those things over time. E85 vehicles that come from the factory are equipped with special components to protect against this.
Old Dec 19, 2007 | 09:26 PM
dave justice's Avatar
dave justice
ORIGINAL: stratusguy02
ORIGINAL: Nofrag
I would. Many mistaken methanol for ethanol. Ethanol is not corrosive like everyone says - it's just moonshine. Methanol iscorrosiveand you would need to change out the components like stated. I've been using ethanol my whole life on the farm and run my 1/4 mile car on on E85. It doesn't harm a thing. It's better than gasoline.
I've seen those conversion kits and they work really well too.
Old Dec 20, 2007 | 08:08 AM
stratusguy02
ORIGINAL: dave justice
ORIGINAL: Nofrag
You are correct, ethanol is just alcohol. The problem is, certain components in the fuel system are not protected from prolonged exposure to ethanol. These components are the rubber seals, injectors and fuel pump. They will work with ethanol, but you will encounter failures over time. Ethanol is not as gnarly as Methanol, but it is still not what the materials that compose a fuel system are designed for. You can do whatever you want on your car, but on my car I will not run Ethanol without changing the fuel system. Look for yourself, check the part numbers on the fuel pump modules at the dealer for a flex fuel truck and a non-flex fuel truck. They will be different because there is a more expensive pump in the FF truck.
