Notices
Will these fit @ all?
Old Dec 25, 2004 | 10:35 PM
SRT4@40's Avatar
SRT4@40
Default Will these fit @ all?
Will these fit my SRT? 2000-02 Dodge Neon Wheels and Tires. The wheels are 15x6, aluminum factory don’t know the offset, and guy doesn’t know how to measure it anyway? These will also look better than Steelie wheels!
Old Dec 26, 2004 | 12:08 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: Will these fit @ all?
to measure the offset...place the wheel face down, and put a string across bead, from one side to the other, Tight....then measure the distance from the string, to the mounting surface of the rim, in mm....that is your offset.
Old Dec 26, 2004 | 01:48 PM
moparturd's Avatar
moparturd
I see you're still hunting wheels. On your stock wheels, how much distance in there between your brake caliper and the inside of the rim. As far as the offset and everything, they should be OK. The only question I have is the caliper clearance.
The SRT stock wheel is a 16, right? So of you have over an inch caliper clearance, I'd have to say that the other wheels would fit with all other things being equal.
Old Dec 26, 2004 | 01:49 PM
moparturd's Avatar
moparturd
Stock Neon aluminum wheels have 40mm offset.
Old Dec 26, 2004 | 07:43 PM
SRT4@40's Avatar
SRT4@40
Nope Factory SRT-4 Wheels are 17"x6.5"
