Notices
rear axle assembly
Old Apr 23, 2008 | 11:17 PM
RebelX's Avatar
RebelX
Default rear axle assembly
I need a complete rear axle assembly for a 1998 or a 1999 Dodge Durango. It has to be the 9 1/4 inch diff housing. 12 bolt cover. 3.92 gear ratio and limited slip with no problems.
please send any pic of one you have for sale to chevyking@hotmail.com mine had a carrier bearing let go and tore up the main housing and ring/pinion and its cheaper to replace than to fix it.
Old May 3, 2008 | 07:51 PM
RebelX's Avatar
RebelX
Default RE: rear axle assembly
bump....
anyone know where one is? i would consider a rear axle with the proper size and gears even if the diff was robbed. mines on just a lil rubbing wear.
i really want my D back up and running........i miss it.
Old Jun 1, 2008 | 12:08 PM
shawnsack's Avatar
shawnsack
i have a 9.25 out of a 96 dodge ram not sure of the gears but do you think it would even come close to what you need?
Old Jun 4, 2008 | 06:55 PM
RebelX's Avatar
RebelX
sadly i dont think the rear housing will fit in my durango. thanks for offering though.
