Notices
2nd Gen Dodge Ram 1500 4x4 parts, shafts, hubs, gear etc.
Old May 3, 2008 | 08:51 PM
Mikeg1005's Avatar
Mikeg1005
Default 2nd Gen Dodge Ram 1500 4x4 parts, shafts, hubs, gear etc.
Haven't been on here in forever.. but I just swapped out my axles for 1 tons in my truck so I got a ton of stock 1/2 ton axle parts and more...
DANA 44...
(1) Brand new ABS hub, timken bearings, from napa : $130 bucks - $315 new and if you don't need the ABS just cut the cable.
I might have two more new bearings, I'm going to go try and warrenty my used ones... but if I don't get them warrentied I have..
(1) used ABS bearing, replaced this summer, has less than 2000 miles on it. - $60
(1) LOADED Stock Dana 44 carrier, 3.73 and down(# higher) - $35
(1) EMPTY Stock dana 44 carrier - $20
(1) set of spider/side gear - $15
(1) CAD unit - $25
(1) diff cover - $15
(2) non ABS brake calipers, left and right - $15 a piece
(2) ABS brake calipers, left and right - $15 a piece
I don't know if theres a difference but I figured I'd tell you
(2) used rotors - $10 a piece
(1) set of almost new brake pads -$15
(1) 3.55 gear set - $40
(1) 4.56 thick gear set yukon - $100 SOLD
(1) Eaton E-locker 3.73 and up(# down) split - $625... Thing has less than 5000 miles on it and was only used on 3 or 4 trips. Last time I saw one it was $760 new and they are rare as hell soo ya..
(1) passnger side axle shaft assembly - $50SOLD
(1) driveside axle shaft assmebly less u-joint - $40 SOLD
(2) intermediate shafts - $15 a piece
(2) knuckles drilled for thuren steering(left and right) - $20 a piece
(1) pinion yoke - best offer
(1) dana 44 bear housing w/ bent inner C's - Free, pickup only, if you want it w/ other parts just toss on the cost of what the parts were listed above.
CHRYSLER 9.25...
(4) axle shafts - $30 a piece
(1) detroit locker - $375 SOLD
(1) 4.56 Yukon gear set - $100 SOLD
(1) dana trac-loc, needs new clutches - w/e you want you can take it for.
(1) chrylser 9.25 diff cover w/ 3/16" steel strips welded onto the bottom half and ring gear hump to use as a slider. - $15
(1) pinion yoke, 7920 joint- SOLD
(1) bear chrysler 9.25 housing - free but you gotta come and get it... before april or its garbage.
OTHER CRAP
(1) black tail gate, a few scratches, rhino lined- $25 bucks SOLD
(2) 16.5" stock steelies 8x6.5 on some dry rotted tires.. whatever you want for them...
(4) American Racing Diamond Back rims 15x8 - $340
(1) set of stock front bumper brackets(4 brackets total) - Best Offer
(4) Blizzak snow tires.. on steelie rims, same bolt pattern as a Camaro is... and w/e size tires will fit on that.. I have to check the size but I believe the rim is a 16"... probably 70% thread left on them.. I'll get some pics if your intersted ... asking -$250 for all 4.
ALL PRICES ARE WITHOUT SHIPPING... PRICES ARE NEGOTIABLE, IF YOU BUY MULITIPLE ITEMS I CAN DISCOUNT SOME STUFF... LET ME KNOW THIS STUFF HAS GOT TO GO!!!
MIke.
