Notices
FS: 2006 SeaDoo GTIse
Old May 13, 2008 | 08:16 PM
Night_Runner's Avatar
Night_Runner
Default FS: 2006 SeaDoo GTIse
2006 SeaDoo GTIse + Yacht Club trailer
33 hours of use
great condition
$7,500
specs and info below pics
Size:  74.1 KBName:  DSC01558.jpg
Old May 13, 2008 | 08:18 PM
Night_Runner
Default RE: FS: 2006 SeaDoo GTIse
Dimensions
Length: 127.0 in. (322.5cm)
Width: 49.0 in. (124.5cm)
Height: 44.4 in. (113.0cm)
Weight (dry): 747 lbs. (338.8Kg)
Rider Capacity: 1, 2 or 3
Fuel Capacity : 15.9 US gallons (60L)
Oil Capacity: N/A
Storage Capacity: 13.2 US gallons (50L)
Engine
Type: Rotax® 4-TEC® SOHC, four valves per cylinder with multi-port fuel injection
Bore x Stroke: 100mm x 63.4mm
Displacement / hp: 1494cc/130hp
Compression Ratio: 10.6:1
Intake System: Naturally aspirated with 52mm throttle body
Cooling: Closed-loopsystem
Fuel Type: Regular unleaded
Drive Unit
Propulsion System: Bombardier Formulawater jet pump
Jet Pump: Composite/aluminum, axial flow, single stage, large hub
Transmission: Direct drive, forward/ neutral /reverse
Impeller: Stainless steel
Electrical
Ignition: Digital inductive
Starter: Electric
Battery: 12 volt
Hull
Type: Modified V, composite
Color: Bright Yellow/ Atlantic Blue
Equipment
Speedometer: STD (Information Center)
Tachometer: STD (Information Center)
Multifunction LED info center: N/A
D.E.S.S. TM: STD
O.P.A.S.TM system: STD
VTSTM: N/A
Sea-Doo® Learning Key: STD
Mirrors: STD
Two-tone comfort hand grips: N/A
Reboarding Deck Pad: N/A
Reboarding Step: STD
Removable Front Storage Tray: STD
Information Center: STD (16 functions)
Standard Package
- Speedometer (Information Center)
- Mirrors
- Footwell mats
- Reboarding step
- Reboarding deck pad
Engines
1494cc four-stroke, Rotax SOHC with four valves per cylinder Reliable performance in fresh or salt water, increased torque at low RPM, optimizes power at all RPM levels and throttle positions.
Multi-Port Fuel injection Better control of exhaust emission and power at all RPM ranges to reduce emissions and reduce fuel consumption.
Sea-Doo® Learning KeyTM Limits engine RPM & top speed for less experienced riders.
Chokeless starting Simple, user-friendly starting.
Close-loop cooling system Insures the proper operating temperature at all speeds and improves corrosion durability.
Watertight digital ignition Provides optimal energy for a consistent spark, ensuring maximum performance.
RPM limiter Protects engine from over-revving.
Warning device Warns operator of engine and exhaust overheating, engine management and system failure.
Handlebar-mounted start/stop button Single user-friendly engine starts and stops with one control button.
Tips Over Protection System (T.O.P.S.TM) Protects engine in case of turn over.
Propulsion System
Bombardier Formula water jet pump Delivers optimum performance with the Rotax engine.
Forward/neutral /reverse Safe operation while docking, trailering or towing.
Composite stator vanes Handles the high-performance engine without erosion.
Dual automatic vacuum siphon pumps Continuously remove water entering the engine compartment.
Large diameter drive shaft with crowned spline design Maintains engine and pump alignment at all operating speeds.
Replaceable urethane wear ring Provides long impeller life, less maintenance and maximum thrust.
Stainless steel impeller Delivers improved acceleration, higher top speed and less cavitation.
Hull and Components
Modified-V design Ensures a smooth and comfortable ride in a variety of water conditions, and greater maneuverability.
Composite Strong, light and easy to maintain.
Sponsons For improved handling.
D-Sea-BeITM System Sound reduction system for a quieter ride.
Bumpers Help protect watercraft from damage while tied to a dock or another craft.
Temporary docking loops Provides access for quick tie-up.
Two-tone, non-slip comfort hand grips Provide extreme hand comfort and great looks.
Reboarding platform For easy and comfortable mounting of the craft in deep water.
Non-slip hand grips For added control and comfort.
Floating safety lanyard Stops engine in manual and emergency situations.
Seat strap Aids in reboarding from water.
Grab handle For easy reboarding and as a passenger handhold.
Water/air separator Provides maximum airflow to engine and reduces water intrusion.
3-up seat Comfortable room for three - permits spotter for watersports.
Watertight storage Provides storage for fire extinguisher compartment and necessities with easy access.
Storage compartment(s) Room for supplies on extended cruises.
Glove compartment Great place to store smaller items.
Removable front storage tray Convenient and portable access to smaller items.
Ski eye Improved for easy and secure attachment of ski rope.
Elevated fuel filler Easy access and prevents water intrusion while refueling.
Multifunction Digital Information Center Reports 16 key operating functions: Fuel Level, Low Fuel Level, Low Oil Pressure, Low Voltage, Hi Voltage, Tachometer, Overheat, Hour Meter, Maintenance Info, Speedometer, Check Engine, Lake Temperature, Sensor, Check Key (battery protection), Key (wrong key), L-Key.
Dual drain plugs Screw type design with built-in retainer for easy removal and installation.
Digitally Encoded Security System (D.E.S.S.TM) Industry's first digitally encoded theft- deterrent system.
External exhaust cooling flush attachment
Easily accessible and fits a common garden hose.
Foam flotation Ride with security and peace of mind.
Meets or exceeds USCG standards.
Operator's guide, Instructional video and booklet Informs you of boating regulations, care, maintenance and operating safety features.
Off-Power Assisted Steering (O.P.A.S.TM) Assists steering during off-power, as well as off-throttle situations.
SE PACKAGE
Adjustable mirrors Increase field of view.
Carpeted footwells and deck pads Offer extra comfort , non-skid surface and great looks.
Built-in reboarding step Grooved fold-down for easy reboarding.
Old May 16, 2008 | 02:36 AM
Night_Runner
bump, any interest?
