Notices
FS:'89 GTC Convertible, Turbo2, 5spd, Mass - $1k
Old Jan 13, 2005 | 10:04 PM
RagingHamster's Avatar
RagingHamster
Default FS:'89 GTC Convertible, Turbo2, 5spd, Mass - $1k
1989 Chrysler LeBaron GTC Convertible
175Hp & 200 lb-ft Tq (yes, more torque than ponys)
T-II Turbocharged & Intercooled Motor
Getrag A-555 5-spd Manual Transmission
Pewter Exterior
Tan Leather Interior
Tan Top
16" Rims
110k-125k Miles (I have to check)
PW, PDL, PM, P-Top, P-Driver's Seat
Infinity Sound
Car is RUST FREE
Here is everything I know that could use attention...
1. A few patches of clear coat are peeling on the hood.
2. Antenna is busted.
3. Speakers work, but could definetly use replacement.
4. Small rattle beneath the car at idle (probably an exhaust shield).
5. Needs a new top, but can be used if you own stock in duct tape.
6. A couple minor dents about 1-2" long.
7. Sometimes stumbles at idle. Runs fine throughout RPMs though. I tried replacing the O2 and MAP sensors, and ended up just driving it.
8. One plug hole has some stripped threads. Plug still goes in ok, and cylinder has proper compression. Just letting you know.
9. Little chrysler badge on inside door panel keeps falling out. Needs glue.
10. Needs new piece of decorative molding on one door.
11. Tires have about 25% tread left.
12. Sometimes a rear window sticks. I hit it with WD and toggle the switch to get it going again.
I'll also include all three '89 Chrysler Service Manuals for this car frame, along with the original supplements given to Chrysler techs (about $80 value). Everything you'll need to do any service from replacing a wiper motor to checking bearing clearences in a rebuild.
Here are some photos...
I'm taking flight lessons now which are crimping my budget to a crawl on other projects I'd like to finish. I know I'll miss it in the summer, as the best way to go fast is with no top, wrapped in leather. Either fix it up nice, or carry duct tape and WD like me. Looks like the guy before me had a lot of work done to it recently (receipts say an engine & turbo rebuild from the looks of it). I took it off the road last fall, so you'll have to pick it up. Runs and drives fine. Car is located in Athol, Massachusetts (north-central portion of the state). Taking offers above $1,000. A great price for a fairly rare car.
eMail me at nicholasmosher@verizon.net (checked 3-4 times a night).
Thanks,
~Nick
