Notices
FS in CT: '85 D150 Long Bed 95k v8 auto Make offer!
Old Jul 10, 2008 | 10:03 AM
distincthead's Avatar
distincthead
Default FS in CT: '85 D150 Long Bed 95k v8 auto Make offer!
First of all, I have no idea what's going on with the apostrophes. To view a non apostrphe riddled at, go here: http://newlondon.craigslist.org/car/749415623.html
I have a truck that I have no time to put money into. I bought it a few years ago to restore while using it, with a bigger engine (has a carbed 318), etc.
It's a 1985, has 95k on it (the odo didn't roll over). The frame is in great shape, still black paint on it mostly, with no rot anywhere. The exterior is in really nice shape, virtually no rust anywhere - it's just starting to rust on the inside of the upper door where the weather stripping was (I took it off of the driver's side to inspect the rust), and a little bit the size of a thumb near the front bumper. That's all that I can think of. Rear bumper has some dents and rust. The ONLY dents on the body panels are in the bottom of the bed, which started to rust about a year and a half ago. Any rust is just surface rust. The interior is dirty, and the bench seat on the driver's side is shredded, but it's not gross and it doesn't smell at all. The power steering pump leaks. Speedometer cable broke 3 or 4 months ago.
It has new rear brake shoes, wheel cylinders, and brake lines. New front pads and rotors, and the lines were drained all around and refilled, then bled. New intake manifold gasket, new voltage regulator, new coil, new oil pressure sender, new alternator.
Last week it failed to start while I was in a parking lot - then after letting it sit for 45 minutes, it started right up. This morning, the same thing... the starter goes, and the engine turns over, it just wont catch when that happens. So now I just want to get rid of it, as I never know if it's gonna pull the no-start thing with me again and I have no desire to put money into it. I think it's because the carb needs to be cleaned. The engine runs good and strong. The trans shifts well. There are no leaks anywhere. It doesn't seem to consume any oil, doesn't smoke. It would make a beautiful project or work truck.
Exhaust has been cut off up to the catalytics - which are still good. Before I cut it off, it passed the CT emissions just fine. That was last year or so, and I obviously haven't had to go thru emissions since I cut the exhaust off, but I'm sure with a new muffler it'd pass.
Price is 1000 or best offer. Tell me what you're willing to pay and we'll see what we can work out. It needs to sell! Email is above, or call 860.228.3494 and leave a msg. Please don't call after 9 PM.
Edit: After spending some time under the hood this morning, I've come to the conclusion that it's something silly that makes it not start at times, probably the distributor cap & rotor. Since it runs well, idles well, and doesn't stall ever, and smelled like fuel the last time it wouldn't start, I don't think it's the carb. Since the igntion was gone through what with the new coil, voltage reg, etc. I don't think it's any of those components. That leaves me with the plugs, wires, dist cap or rotor.
