Notices
Deisel Preformance 5.9 Edge Products juice with attitude! Possable Buy
Old Feb 3, 2005 | 12:33 AM
04sicasstib's Avatar
04sicasstib
Default Deisel Preformance 5.9 Edge Products juice with attitude! Possable Buy
Hey Everyone I came across this item and it looks like a killer deal just wanted to pass it on ! Easy Installation
Here are some installation pictures!
If you are intersted you can get this unit for $819.00 shipped to you door! please just pm me with any inquires!
***If you have any ?'s please feel free to call the Route 66 SOUND Factory 626-633-0300 Company who installed mine!
The Edge Juice/Attitude is a highly sophisticated package capable of dramatically improving your Cummins’ driveability, towing, mileage and, most importantly, POWER.
Using factory-style connections in just ten minutes you can add five levels* of adjustable power ranging from 40 to 100 horsepower – and increase torque up to 250 ft. lbs. The Juice greatly improves responsiveness and driveability, while at the same time increasing fuel economy.
When used in conjunction with the Attitude monitor you can control the five power levels on-the-fly from inside your truck. The Attitude displays all the information a complete set of gauges would and will automatically monitor and display exhaust gas temperature (EGT), turbo boost and transmission slip and de-fuel the engine to prevent excessive EGT, boost levels or transmission slippage. It also displays 0 – 60 times, quarter mile times and actual speed if you are using non-stock tires as well as a host of other parameters.
The following power gains are representative of a 5.9 Dodge Cummins (600 Series) equipped with the Juice module with Attitude monitor:
Level 0: Stock
Level 1: 25 Horsepower - 80 Foot Pounds of Torque
Level 2: 40 Horsepower - 120 Foot Pounds of Torque
Level 3: 60 Horsepower - 150 Foot Pounds of Torque
Level 4: 80 Horsepower - 200 Foot Pounds of Torque
Level 5: 100 Horsepower - 250 Foot Pounds of Torque
Imagine, within minutes you get incredible power gains, an increase in mileage and the equivalent of a complete set of gauges with one simple installation!
The Juice communicates directly with the engine’s ECM, from which it receives vital engine and fuel system information. This enables the Juice to provide smooth and precise power in real time under any driving condition.
Adjustability has never been easier or looked better. The new in-cab controller combines sleek new engineering with cutting edge technology to provide state-of-the-art performance in adjusting levels, reading EGT and boost. With the addition of the controller, there will no longer be a need for gauges. With the backlit LCD display screen, EGT temperatures and boost readings will be displayed for easy and clear reading. With the push of the mode button, you can switch power levels and have adjustability on the fly.
The Cummins motor is one of the most powerful motors ever put in a pickup truck. The Edge EZ module unleashes the potential of this monster by carefully monitoring RPM, turbo boost pressure and fueling parameters and adjusting fueling to maximize power, torque and driveability.
The Edge EZ module allows maximum fueling at full turbo boost and provides an additional 65 rear wheel horsepower and an additional 150 foot pounds of torque. Simply plug the Power Edge EZ connectors into the ECM Data Link connection and MAP sensor. The Edge EZ is completely weatherproof and mounts under the hood. For 2004.5 and later trucks, the EZ has three levels of adjustability ranging from 25 to 65 additional horsepower.
The EZ can also be stacked with other upgrades to deliver even more power. There is not an upgrade on the market today that can deliver as much power and install so simply.
