Notices
1997 Turbo Neon Coupe
Old Oct 20, 2008 | 02:40 PM
50trimsohc's Avatar
50trimsohc
Default 1997 Turbo Neon Coupe
Need to get rid of this so i can pay some stuff off and i just found this site so i thought i would post it up here.
Year: 1997
Make: Dodge
Model: Neon
Doors: 2
Color: Red
Trans: 5speed
Motor: 2.0L sohc
Info: I has manual windows,locks,and mirrors. Air Conditioning and Power Steering is removed(worked great when removed but i needed the room.) Battery is in the trunk. Heat works good. Has a new headgasket/timing belt.
Motor: It is a sohc 2.0L with around 35,000 miles now(very low original miles out of a 1999 neon) I will get the exact number when i go out to the car. It was put in with 124,xxx miles(on the body)and had 14000 when i bought it and its around 145,000(on the body) so its right around 35000. It also has an underdrive pulley(udp), exhaust studs, egr blockoff kit, 52 mm throttle body, and msd coil and wires.
Trans: Transmission is stock with 145,xxx miles. No leaks,grinds,rear main was replaced,ect.
Clutch/Flywheel/TOB:All bought brand new when i got the motor so they have around 20,000 on them now and hold very strong. Clutch is a centerforce dual friction, flywheel is a stock 95 style.
Suspension:Stock struts with eibach sportline springs.
Exhaust: stock piping to a aftermarket muffler
Body: Its in ok shape, there are some scratches and dings for being 11 years old, also 1 flat spot on the rear quarter about a foot long but barely noticeable. it has projector headlights, clear corners, wings west front bumper.
Wheels/Tires: Wheels are MB Motorsport Boost's in Gunmetal. 15x6.5". Tires are bfgood traction t/a's 195/60/15
Turbo kit: t3 manifold with external wastegate flange, 6psi wastegate,t3/t4 to4e 50 trim turbo, 5 bolt 2.25" downpipe, earls ss oil feed, 2.5" intercooler piping, srt4 intercooler, bov, 36lb injectors,chill factory rising rate fuel pressure regulator,fuel canister set up for feed and return line with walbro 255 pump, 6an feed and return.
Gauges/pod: triple pod on the apillar with all pro comp ultra lite gauges(srt boost,oil, and volt) have a fuel psi guage under the hood.
Interior: gutted the rear seats(have them still) has a cd player, seats are kinda dirty but seat covers would help or new seats.
I am located in South Eastern Minnesota on the Iowa/Wisconsin border.
Asking price is $3500
Possible Trades just let me know what you have.
Email is 50trimsohc@inbox.com
http://www.cardomain.com/ride/672936 Pics are here. im going to take a lot more pictures of it today sometime so i will post them on there and let you know when i updated it. Thanks.
Old Oct 22, 2008 | 06:02 PM
BackToBlack's Avatar
BackToBlack
do you by any chance know what the car would run in the 1/4 mile
Old Oct 23, 2008 | 12:57 PM
50trimsohc's Avatar
50trimsohc
I had the same setup on it a year ago and the only thing that was different was i was running a t3 daytona turbo instead of this big one and when i had the t3 on it, it ran a 13.7@102, this turbo is a lot bigger and it pulls a lot harder. id give it low 13's, which is pretty good for a stock sohc and only running 6 psi.
