DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   Archived Classifieds (https://dodgeforum.com/forum/archived-classifieds-163/)
-   -   97 Ram Skyjacker 8" lift, 360, 35's, LMC (https://dodgeforum.com/forum/archived-classifieds/195513-97-ram-skyjacker-8-lift-360-35s-lmc.html)
shawngrace5 Mar 31, 2009 07:31 PM
2 Attachment(s)
97 Dodge Ram 1500 4x4
5.9L 360 Engine
140,000 Miles
SEE ATTACHED FOR PICS
8" SkyJacker Suspension Lift (NO BODY LIFTS)
35" Pro-Comp X-terrains on 17" IONS (New Last Summer)
Sony MP3 CD Player w/ 2 Kicker Subs and 350 Watt AMP
(could use a bigger amp)
Dual Exhaust- 3" Pipes with 4.5" Tips....IT ROARS
No Mufflers, CAT punched out.
http://www.youtube.com/watch?v=iQZBSIwYigM
Needs Transmission Work
(delayed shift points)
could just be a shift selonoid
or could need a rebuild.
It was always a good shifting transmission and all of a sudden started stay in first and second gear alot longer than its suppose to.
The engine has ported and polished heads with a mild cam
Its got a nice chop to it when it idles.
Complete MSD Ignition (From Plug Wires, Coil, and MSD 6AL Box)
4.56 Rear End Gear (have front 4.56, but needs installed)
Rear End was built last summer with 4.56 Gear
All High Performance Parts- built to handle over 750 horsepower
Cost me $800.
New Ball Joints, Tie Rods, U Joints, and Wheel Bearings
New Pro Comp Steering Stabilizer
New Radiator (old one was leaking)
New 180 deg. Thermostat
New Fuel Pump (just installed yesterday)
the other one was low on pressure
Front Differential is Leaking a little bit, I haven't fixed it lately
because I've been wanting to change out that front gear.
This truck has been my pride for the past two years, unfortunately my outlaw late model race car is top of my list and is why I am forced to let my truck go.
Last summer I got bored with the looks of the front end so I dropped ALOT of money into an LMC front end
Dual Ram Air Hood, Never seen another dodge with this hood! ($600)
LMC Chromed, Billett Front Grille ($250)
LMC Chrome Billett Grille Bumper ($500)
Chrome Upper Bumber Cover ($200)
Lower Bumper Cover Prof. Painted same color as truck, Very Neat
LMC Clear Headlights w/ Corner Lights ($250)
E-mail me for MORE PICTURES @ Gracsr01@ipfw.edu
Call Me @ (260) 350-2972
$4500, OBO.
I have over $10k in this truck, BAD ASS TRUCK
After its all said and done I will kick myself in the ass for selling!
Transmissions are cheap to build if you know what your doing.
Transmissioncenter.net has a high performance re-build kit
for less than $400. Cant beat that with a stick.
For a little extra I will rebuild the Transmission,
from mild to wild your call.
the don Apr 15, 2009 04:14 PM
hows it run on the highway? does it only have problems shifting when its cold? will it pass inspection?
shawngrace5 Apr 16, 2009 07:45 PM
Runs great on the highway........highway gives me no problem at all. Its only first and second gear that give me problems. I recently drove it about an hour away and back and it pulled 16 average to the gallon. I will be completely honest with you about everything so feel free to ask questions
It actually shifts better when its cold, when it warms up is when it doesnt want to shift out of first or second gear. If i put it in neutral and back to drive it will often shift. Which leads me to believe the pressure selonoid might be bad. (Neutral creates more pressure than drive meaning when you put it in neutral and back to drive it creates more pressure than in drive and then it allows it to shift)
What kind of inspection? The truck is a real solid truck. Runs great, engine has never given me any problems. I just put a new spark plugs in it and there isn't any rust on it either. I've kept the truck rubberized underneath since I've had it. The paint is in pretty good shape.........there is a part of the paint that peeled off a little bit on the door when I removed the pinstripes but you can install the pinstripe moldings back over it if you would like.
I was actually getting ready to pull the transmission out and rebuild it, but I wont if your interested. Make me a decent offer and if it pays off my loan then you can have it. I love this truck and I hate to see it go but I dont really want to pull the transmission out and rebuild it. I have too much going on in my life right now to be doing that.
If you would like give me a call (260)350-2972
the don Apr 21, 2009 02:54 PM
interior and tailgate pics?
shawngrace5 Apr 21, 2009 08:05 PM
Here ya go..........follow that link let me know if you have problems I can e-mail them to you too
http://img19.imageshack.us/gal.php?g=1000396s.jpg
© 2026 MH Sub I, LLC dba Internet Brands
