Notices
Viper 2800 Stall, K&N Cold Air Intake, Perofrmance Cam, Etc.
Old Apr 9, 2009 | 09:16 PM
Durango911's Avatar
Durango911
Post Viper 2800 Stall, K&N Cold Air Intake, Perofrmance Cam, Etc.
I have a garage full of 98-2003 Dakota/Durango parts. From A/C compressor,alternator,water pump,front accessory bracket, clutch fan,map sensor,coil,V6/V8 Throttle Bodies,etc. Make me an offer! I'm redoing my 98 dakota and 99 durango. I accept paypal, money orders, etc. I live in Michigan. I would post pics but I'm on dial up and it takes forever. If you really need them I can probably e-mail some from work. I have 2 jobs so sorry if I don't reply right away! I have this listed on several other dodge forums. You can also e-mail me at blamrouex3843@charter.net
Viper 2800 Stall for 44RE Transmission, comes with all hardware (barely used) - $500
K&N CAI Kit (could use a new air filter but I'll clean/oil before selling!) - $125
Underdrive Pulley kit with belt (only 500 miles on belt,ALT/Crank pulley) - $75
Stock Injectors - Make an offer
5.9/360 Flexplate - Make an offer
Ported\Milled\Modified Runners,Ported TB opening to 52MM, Kegger Intake (non EGR)-$100
.544/.544 218/228 @ .050 Roller Cam with proper valve springs-$175
Cloth Bucket Seats - Make an offer
1998 Dakota 3.9 V6 Engine, 100K Miles(still have to pull,left in truck so you can hear it run) - $500
1998 Dakota 2WD,V6,42re? transmission 100K miles(still in truck, till it sells) - $300
1999 Durango 9.25 Rear Differential,3.55 Gears,drum brakes, 150K Miles(still in suv, till it sells) - $200
A.R.E. Fiberglass Tonneau Cover, Black,needs new lock/hardware, has small cracks by lock,repairable- $200
1999 Hughes Engines/B&G Chrysler Stage II computer (raised shift points,more timming, accepts larger cam) - $200
Old Apr 10, 2009 | 05:35 PM
trucklover's Avatar
trucklover
PM sent on the kegger intake
