Notices
2nd gen axle stuff, hubs, gears, brakes, shafts, etc.
Old May 19, 2009 | 11:15 AM
Mikeg1005's Avatar
Mikeg1005
Default 2nd gen axle stuff, hubs, gears, brakes, shafts, etc.
Alright cleaning out the garage... again...
All parts came off a 1998 dodge ram 1500 4x4 quad cab w/ a 360.
All parts used unless stated otherwise.
Dana 44
diff cover - $10
(2 sets, ABS and non) brake calipers - $10 each
(2 sets, one almost new, one w/ 15k)brake pads - $10/5 each
Hub bearings - all ABS, napa brand, timken bearings
(1) new - $100
(1) 2000k on it - $75
(1) 2 years old - $50
Hubs all in good working condition when removed.
Carriers - both 3.92 and up(numerically down)
(1) empty carrier - $10
(1) loaded(spider/side gear) carrier - $15
(1) set of spider/side gears w/ cross pin - $10
(2) intermediated shafts - $10 each
(1) 3.55 gear set - $15
Chrysler 9.25
(4) axle shafts w/ lug studs - $20 each
(1) diff cover w/ 3/16" plates welded for protection - $10
(1) pinion yoke - $10
Also have 15x8 rims 5x5.5 check other post
All prices DO NOT include shipping, all prices negoitable.
Located in NW suburbs of Chicago, IL.
MIke.
Old May 20, 2009 | 12:55 PM
01dabram20's Avatar
01dabram20
sent you a pm
Old Sep 19, 2011 | 03:27 AM
peshewa's Avatar
peshewa
Hey man, the 3.55 gears interest me & maybe the sun gear assembly also. I can drive out for it, I am in eastern Iowa.
Old Sep 19, 2011 | 02:34 PM
jasonw's Avatar
jasonw
Site Moderator
Peshewa, I doubt he will respond. If you look at the thread date, its from 2009. The last time the seller was online was August of 2009.
On a side note, I have a set of 3.92 gears if you're interested.
