Notices
97 Dodge Ram Skyjacker Lift, Defective Transmission Cheap
Old Jun 4, 2009 | 04:04 PM
shawngrace5's Avatar
shawngrace5
Default 97 Dodge Ram Skyjacker Lift, Defective Transmission Cheap
97 Dodge Ram
8" Skyjacker Susp Lift
35" Pro Comp X-Terrains on 17" Ions
(Tread still has about 70% left-New Last Summer)
Has a dual cowl induction hood
Billett Grille, Chrome Bumper from LMC truck, and Crystal Clear Headlights from LMC Truck
Big, Loud, Nice, Turns alot of heads
Needs Transmission Work
I just completely rebuilt the Transmission
and something is wrong with it.
Doesn't shift like it should
Stays in first gear for the most part.
I think the problem lies in the overrunning clutch
in the over drive unit, but I dont know enough about it to fix it
Paint and Body is in pretty good condition
No dents, no rust, paint is in decent shape (I say 7 out of 10)
Small dings and scrapes here and there
Front end is straight and in great shape
(New balljoints 2 months ago, new tie rods, u joints, wheel bearings)
Dual Exhaust system, no mufflers, loud, deep, sounds awesome
3" pipes with 4.5" tips
Engine is 360 with port and polished heads,
mild cam, Holley Throttle Body, MSD Ignition System
4.56 rear end gear, have 4.56 for front but it needs installed (3.92 still in)
The transmission main case should not have to be pulled out, I think the overdrive unit has a problem and I already have OD unit and transfer case out of truck. (Saves you alot of labor, only will need reinstalled after fix)
Unless main case has a problem, which is a possibility, but its all rebuilt
I will take $2800 if you are interested e-mail me and I will send you some pics
gracsr01@ipfw.edu
or Call me at (260)350-2972, Shawn
No trades for 4-wheelers or anything stupid like that I owe 2500 and it has to get paid off
Truck is located in Orland, IN
