Notices
98 99 00 01 02 03 durango and dakota complete engine bay part out
Old Jan 25, 2010 | 01:22 PM
norcalaudi's Avatar
norcalaudi
Default 98 99 00 01 02 03 durango and dakota complete engine bay part out
I HAVE A 2000 DODGE DURANGO 4.7 WITH VIN "J" THAT THE RIGHT HEAD WENT OUT SO IM PARTING OUT THE ENGINE AND THE ENGINE BAY. I AM NOT PARTING ANYTHING OTHER THE THE ENGINE BAY SO PLEASE DONT ASK FOR SEATS OR AXLES OR DOORS, JUST ENGINE STUFF. IF YOU ARE INTERESTED, PLEASE SEND AN EMAIL TO norcalaudi@hotmail.com I HAVE PICTURES OF EVERYTHING SO SEND ME A EMAIL AND ILL SEND YOU PICS. EVERYTHING WORKS. CAR ONLY HAD ABOUT 80K MILES ON IT. I LIVE IN NAPA, CA BUT I AM WILLING TO SHIP OUT WHEREVER YOU ARE. I HAVE A PAYPAL ACCOUNT OR YOU CAN SEND ME A CHECK OR MONEY ORDER WHATEVER YOU PREFER OR COME PICK IT UP. THANKS. BELOW IS EVERYTHING I HAVE:
COMPUTER MODULE R6029124AC (2003 DURANGO)
FEUL INJECTORS
ELECTRONIC COILS
STARTER
ABS MODULE
BRAKE MASTER CYLINDER
VACUME MODULE
WINSHIELD WASHER MOTOR
COMPLETE INTAKE MANIFOLD
WATER PUMP
SERPENTINE BELT (10K MILES)
SERPENTINE TENSIONER AND PULLYS
A/C COMPRESSOR WITH RESOVIOR AND PIPES
POWER STEERING PUMP WITH PIPES
ALTERNATOR
RADIATOR FLUID AND WINDSHIELD WASHER FLUID RESOVOIR WITH MOTORS AND PIPES
CRANKSHAFT (PERFECT CONDITION, NO SPUN BEARINGS)
LEFT CYLINDER HEAD (CLEAN AND IN GOOD CONDITION)
ROCKERS (ONLY HAVE 6 LEFT FROM OTHER HEAD)
LIFTERS
CAMSHAFT CAPS
OIL PUMP
TIMING CHAIN COMPLETE KIT (REPLACE THE GUIDES AND YOU HAVE DAMN NEAR A NEW SET
CYLINDER HEAD BOLTS (2 SETS)
PISTONS AND RODS IN GOOD SHAPE, JUST BUY NEW RINGS (7 REMAINING)
EXHAUST MANIFOLD (BOTH SIDES)
OIL PAN AND OIL PUMP SUCTION PIPE
CAMSHAFT COVERS (BOTH SIDES)
OIL DIP STICK
OIL FILLER RESOVOIR
FAN
FLYWHEEL AND SPACER
ENGINE MOUNTS (2003 DURANGO)
CRANKSHAFT PULLY WITH BOLT
FRONT ENGINE MOUNT (ENTIRE METAL PIECE THAT WATER PUMP, WATER PIPES, ALTERNATOR, POWER STEER PUMP AND A/C COMPRESSOR MOUNT TO.
AND FINALLY I HAVE THE BLOCK THAT NEEDS TO BE TAKEN TO A MACHINE SHOP. CYLINDER 8 HAS A CRACK BUT IVE TALKED TO A REPAIR SHOP AND THEY SAID IT RUNS ABOUT $500 TO BORE IT AND PUT A SLEEVE IN IT.
AGAIN I HAVE PICTURES OF EVERYTHING SO PLEASE EMAIL norcalaudi@hotmail.com or call 707-363-0520 FOR FURTHER QUESTIONS OR PICTURES. THANKS
DODGE DURANGO DAKOTA 4.7 ENGINE PART OUT 98 99 00 01 02 03 1998 1999 2000 2001 2002 2003
FEUL INJECTORS
ELECTRONIC COILS
STARTER
ABS MODULE
VACUME MODULE
WATER PUMP
ALTERNATOR
LIFTERS
CAMSHAFT CAPS
OIL PUMP
PISTONS AND RODS IN GOOD SHAPE, JUST BUY NEW RINGS (5 REMAINING)
OIL DIP STICK
OIL FILLER RESOVOIR
FAN
FLYWHEEL AND SPACER
TIMING COVER FRONT ENGINE MOUNT (ENTIRE METAL PIECE THAT WATER PUMP, WATER PIPES, ALTERNATOR, POWER STEER PUMP AND A/C COMPRESSOR MOUNT TO.
FEUL INJECTORS
ELECTRONIC COILS
STARTER
ABS MODULE
VACUME MODULE
WATER PUMP
ALTERNATOR
LIFTERS
CAMSHAFT CAPS
OIL PUMP
OIL DIP STICK
OIL FILLER RESOVOIR
FAN
FLYWHEEL AND SPACER
FEUL INJECTORS
ELECTRONIC COILS
STARTER
ABS MODULE
VACUME MODULE
WATER PUMP
ALTERNATOR
LIFTERS
CAMSHAFT CAPS
OIL PUMP
OIL DIP STICK
OIL FILLER RESOVOIR
FAN
FLYWHEEL AND SPACER
FEUL INJECTORS
ELECTRONIC COILS
STARTER
ABS MODULE
VACUME MODULE
WATER PUMP
ALTERNATOR
LIFTERS
CAMSHAFT CAPS
OIL PUMP
OIL DIP STICK
OIL FILLER RESOVOIR
FAN
FLYWHEEL AND SPACER
I HAVE A FEW PARTS I AM SELLING OFF A 4.7L V8 DODGE MOTOR. WILL FIT YEARS 1998 1999 2000 2001 2002 2003 98 99 00 01 02 03. WILL FIT DURANGO DAKOTA AND RAM I BELIEVE. IF YOU ARE INTERESTED IN ANYTHING, PLEASE SEND AN EMAIL TO norcalaudi@hotmail.com I HAVE PICTURES OF EVERYTHING SO SEND ME A EMAIL AND ILL SEND YOU PICS. EVERYTHING WORKS. CAR ONLY HAD ABOUT 80K MILES ON IT. I LIVE IN NAPA, CA BUT I AM WILLING TO SHIP OUT WHEREVER YOU ARE. I HAVE A PAYPAL ACCOUNT OR YOU CAN SEND ME A CHECK OR MONEY ORDER WHATEVER YOU PREFER OR COME PICK IT UP. THANKS. BELOW IS EVERYTHING I HAVE LEFT:
LEFT HEAD CAMSHAFT ROD (CAM)
STARTER
ABS MODULE (1 IN PORT, 2 OUT PORTS
WATER PUMP
RADIATOR FLUID AND WINDSHIELD WASHER FLUID RESOVOIR WITH ALL MOTORS
I ALSO HAVE A 4.7L ENGINE COMPLETE WITH EVEYTHING THAT NEEDS TO BE REBUILT BUT WAS RUNNING, I AM ASKING FOR $1000 FOR THAT. EMAIL FOR DETAILS.
AGAIN I HAVE PICTURES OF EVERYTHING SO PLEASE EMAIL norcalaudi@hotmail.com FOR FURTHER QUESTIONS. THANKS
I HAVE A BUNCH OF PARTS I NEED TO GET RID OF THAT CAME OFF A 2000 DURANGO 4.7L V8 WITH ABOUT 80K MILES ON IT. EVERYTHING IS IN WORKING CONDITION. WILL FIT MOST MODELS BETWEEN 1998 1999 2000 2001 2002 2003. AND SHOULD FIT DURANGO DAKOTA RAM AND SOME OTHER JEEPS CHRYSLERS. BELOW IS A LIST OF EVERYTHING. I ALSO HAVE PICS OF EVERYTHING SO IF INTERESTED IN ANYTHING PLEASE EMAIL norcalaudi@hotmail.com OR CALL 707-363-0520. I HAVE A PAYPAL ACCOUNT YOU CAN SEND PAYMENT TO OR IF YOU WOULD LIKE TO SEND A MONEY ORDER OR COME PICK UP THATS FINE. IF THE PRICES DON'T SEEM REASONABLE, MAKE ME AN OFFER. I LIVE IN THE BAY AREA, CA
NEW FRONT CERAMIC BRAKE PADS $35
NEW FRONT STANDARD BRAKE PADS $20
LEFT CYLINDER HEAD $120
TIMING COVER (FRONT OF ENGINE) $60
INTAKE MANIFOLD (COMPLETE) $60
ECU COMPUTER OFF A 2003 R6029124AC $75
STARTER $40
OXYGEN SENSOR UPSTREAM $20
OIL PUMP $50
WATER PUMP $20
OIL FILLER RESERVOIR WITH CAP $25
BELT TENSIONER PULLYS WITH 2 GOOD BELTS $25
COOLANT AND WASHER FLUID RESERVOIR WITH CAPS $30
ABS MODULE (1 HOLE INLET, 2 HOLE OUTLET) $55
BRAKE MASTER CYLINDER $40
FLYWHEEL WITH DUST PLATE $25
REAR WINDOW WASHER FLUID PUMP $25
AGAIN PLEASE EMAIL norcalaudi@hotmail.com OR CALL 707-363-0520 FOR FURTHER QUESTIONS, THANKS
STARTER $40
OIL PUMP $50
WATER PUMP $20
Old Jan 25, 2010 | 03:27 PM
Duranged408's Avatar
Duranged408
I CALL DIBS ON THE SEATS/DOORS/AND AXLES!!!!!!!!!!!!!!!!!!!!!!
Seriously dude... 1rst post fail...
FAIL!!!!!!!!!!
Make yourself known before promoting, it just leads to random drunk phone calls from big hairy females looking for a good time... You'd been better off posting in the "FOR SALE"..
For all you drunk hairy women, heh and men...
NorCal:
Old Jan 25, 2010 | 08:55 PM
SumAmerican's Avatar
SumAmerican
all caps like crazy bro... my eyes about fell outta my face before i finished the damn sales pitch..
