Notices
Tuner Dodge Neon $35,000 Invested
Old Apr 27, 2005 | 11:57 AM
80mopar's Avatar
80mopar
Default Tuner Dodge Neon $35,000 Invested
1998 R/T Tuner Racing Dodge Neon. Over 35K Invested.
From the Paint to the Engine this thing is unreal. The Engine was custom built by Best Machine Racing engines of Michigan using only the best of components. The Cars owner who is a professional Car Painting Perfectionist applied the paint. The components on this car will be listed below. The miles on the Engine and Drivetrain are under 800 (BREAKIN)… If you have any questions please feel free to email me and I will try to answer them or find someone to answer them to the best of my ability. Like Stated in the title, there is over $35,000 invested in this car. As you can see from everything listed there were NO corners cut on this car. Every Receipt was kept and is onhand for quick answers. Payment must be made with a Certified Cashiers Check or Cash. NO TIRE KICKERS.
$17,000 OBO
Engine Components:
• 2.0 Liter Chrysler 4 Cylinder
• Race Balanced Engine Assm
• Custom Ross Pistons
• Eagle Rods
• Stainless Steel Valves
• Indy Intake Manifold (port matched)
• Competition 6Angle Valve Job
• Crane Springs & Retainers
• Race Ported Cylinder Head Assm
• Race Ported Turbo Manifold
• Crane Turbo Grind Racing Cams
• Nitrated Crankshaft
• Hahn Ported Turbine Housing
• Moroso Oil Pan
Engine Goodies:
• Custom Made Fuel Rail
• 625 cc/min Accel injectors
• Modern Performance Throttle Body
• MSD 8.5 MM Plug Wires
• Hahn RaceCraft Front Mount Intercooler
• Greddy Type-s Blowoff Valve
• Unorthodox Racing Pulleys & Adjustable Cam Gears
• 20 GH TURBO With upto 30LBS of Boost (Oil & Water Cooled)
• TEC 3 Stand Alone ECU Computer System
• Greddy Exhaust Temp Sensor with Warning & Memory
• APEX’I AVC-R Type R Boost Controller
• Urethane Motor Mounts
More Goodies:
• Clutchmasters Stage 4 Modular Clutch
• Driveshaft Shop Stage 3 Axles & Hubs
• Quaife Limited Slip Differential
• KONI Adjustable Struts
Even More Goodies:
• Custom Made Front Fascia
• Viper Style Hood
• GTS Viper Style Rear Spoiler
• RX 300 Style Taillights
• Urethane Bushing Kit
• Booger Bushings
• Custom Flamed Paint Job
• Modern Performance 3" Polished Mandrel Bent Exhaust System
• Custom Made CHROMEMOLY Welded Rollcage
• 5pt Racing Harnesses
• B&M Short Throw Shifter
• Autometer Gauges
• Greddy 60mm Elctronic Peak/Hold EGT Gauge
• EIBACH Suspension Kit
• 17" MOTEGI MR5 Racing Wheels
• BFG G-Force T/A Tires
Contact Info: 80mopar@comcast.net or PM me
Old Apr 27, 2005 | 01:06 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: Tuner Dodge Neon $35,000 Invested
dyno numbers? track times?
i just cant imagine spending 35k on a 1st gen neon...ive seen 9 second cudas that had less than that invested....
it does look good though....
Old Apr 27, 2005 | 01:27 PM
80mopar's Avatar
80mopar
Sorry No Track or Dyno Digits.
To each is own when it comes to spending money. The car owner just wants out of this project.
