Notices
05-08 dakota custom order exhaust.
Old Oct 22, 2010 | 10:39 PM
tmackiefabrication's Avatar
tmackiefabrication
Default 05-08 dakota custom order exhaust.
So i spent months searching the internet trying to find a good dual side exit exhaust that exits in front of the rear tires on my 07 dakota . Instead i recently decided to make one . I made the original out of a flowmaster 40 series single to dual muffler and 2.5 in 16 ga. aluminized steel. it replaces from the midpipe connection in front of the resonator and back. it eliminates the original muffler and resonator which is the same place pretty much all cat back kits for this truck start at. i have some pics below of right after i fabricated it. it is a bolt on system you just cut the old clamp in front of the resonator and replace with the new exhaust system and clamp i will include a strap hanger for the muffler which is the only hanger this needs i welded round bar to my muffler and frame which if you can is the best way to secure it from moving. e-mail me if your intersted the price is $450 for the stainless system. it sounds and looks amazing e-mail for more pics of under the truck and the side while installed which i will have tomarrow when the sun's out .
[IMG]file:///C:/Users/tommy/AppData/Local/Temp/moz-screenshot.png[/IMG]
Old Oct 23, 2010 | 01:05 PM
dakota_raven's Avatar
dakota_raven
The pic is not showing and i think that you need more than 25 post to sell in here. You will get a notice from a moderator! Good luck on the sale!!!
Old Oct 25, 2010 | 10:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
noticed.....LOL
The picture is not showing up because you are trying to upload it from you local PC (hard drive) and this will not work. It has to be uploaded to a file sharing site and then the link posted. The reason is because your PC is not online all the time (assuming you turn it off) whereas file servers are online all the time.
As said before, you need a minimum of 25 posts to place an ad and so it is what it is.
IMO you are priced too high to a simple catback system but I am assuming you are thinking of your time invested in this also since you made it yourself??
Without pics I am assuming it is large and would be hard to ship. That means you might be better placing it on CL or other local oriented sites.
If you want to be an active member and show it off in the Dakota section (not for sale but just showing off your work and inventive skills) then thats fine. Maybe that will help your post count.
Until then, thread is locked due to post count. Sry.
