Notices
Front and rear differential - 03 Ram 1500 - Alberta
Old Oct 24, 2010 | 03:08 PM
freestyledude's Avatar
freestyledude
Default Front and rear differential - 03 Ram 1500 - Alberta
3.55 gears, front differential is in great shape swapped it out for a unit with lower gears to match a newer rear end. Rear differential is a victim of the c-clip issue, it was making a shrieking noise once in awhile while accelerating, so I swapped it out. Rear differential has leaf springs, rotors and brake lines still attached, one leaf broken on the drivers side. Can send pictures, video of any tests you want me to do.
Located near Calgary, AB
Front differential - $250
Rear differential - $200 w/leafs, $100 for just the leaf springs
Old Oct 25, 2010 | 10:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Must post pics per section rules
