Notices
03 5.9 360ci 99% complete engine and 46RE 2WD Trans
Old Jan 15, 2011 | 08:38 PM
Chris Mallett's Avatar
Chris Mallett
Default 03 5.9 360ci 99% complete engine and 46RE 2WD Trans
These two items were removed from a 2003 RC/SB that we installed a 12 valve Cummins in. The engine and trans had 93k miles on them, no programmers or chips to our knowledge, ran great. We removed it and never separated them, have been covered up in a heated garage. Engine needs a distributor and a couple sensors (water temp and oil pressure) to be complete. Still has the exhaust manifolds as well. Since feeler ads are not allowed, I will have to put a price of $600 on the engine alone.
The trans is a 46RE 2wd that shifted perfect. No leaks when it was pulled, like mentioned before it is still bolted to the engine. Complete from the converter to the pan, all stock. Never towed with, the truck has no hitch. Looking for $500.
Feel free to make an offer, not sure if I priced this correctly or not. This was a good running engine in a cruising truck, sitting on 22's and no hitch. The truck was purchased with intentions of putting in the 12ver, this is the only reason these two pieces were removed. Finally figured out we were not going to use either for a different project, so it needs to go. PM me or shoot me a text at 3oh4.65one.14four7. Thanks for looking.
Old Jan 16, 2011 | 11:21 AM
wewanaplay's Avatar
wewanaplay
I am interested in your engine and trans. where are you located?
Old Jan 16, 2011 | 11:34 AM
Chris Mallett
In West Virginia. I travel for my work so maybe I could help you out on getting it closer to you. Feel free to call me, I am headed out of town tonight.
Old Jan 16, 2011 | 12:20 PM
Chris Mallett
Old Jan 16, 2011 | 12:24 PM
Chris Mallett
Since a pic is required I figured a pic as it was being set out will do. Missing the alternator from the front but the PS pump, A/C compressor, water pump, fan, etc. is still intact. If we have loose parts that have been unbolted they are yours as well. Pretty sure the starter is still on it also.
Old Jan 16, 2011 | 04:50 PM
Chris Mallett
Leaving out for work, please call or text unless you want me to reply to this next weekend. Thanks Chris
Old Jan 22, 2011 | 10:28 AM
Chris Mallett
Bump Bump...
Old Jan 28, 2011 | 10:56 PM
Chris Mallett
Headed back to the top.
