V6 Throttle Body from 3.9L Magnum
Yes as long as you have the same type 2 black plastic linkage with the ferrule end cable. Late 1994 and 1995 had this linkage only. This is also an egr throttle body as well, all 1992-1995 dodge and jeeps were egr, then in 1996 they all became non egr. You can not swap egr and non egr throttle bodies without modifying them or they will create high idle issues. To answer your question, yes it will fit your truck as a direct bolt on replacement as long as you have the same linkage style.
