FS: Spal-PWM-V3 Electric Fan Controller
Probably one of the best fan controllers out there and everyone wants an e-fan. Can't have one with a fan controller...off of the website:
FAN-PWM-V3 / Programmable Electric Fan Controller
SPAL's all new programmable fan controller allows you to vary the speed of a single SPAL cooling fan based on engine temperature. This results in increased fan life and reduced operational noise.
You simply choose the Low and High temperature settings you desire. When the low temperature setting is reached the fan begins spinning at 50% speed. As the engine temperature increases, the speed of the fan slowly increases until it reaches the High setting, where it is then running at 100%.
The system can operate dual fan setups with the ability to trigger an external fan relay to power your second fan. An input for your air conditioning system allows fans to run at 100% when the A/C is activated. Built in timing features keep fans off during modern vehicle defrost cycles. On board status indicator lights report error codes and let you know the FAN-PWM-V3 is active and ready.
Many new additional features including fan status output for in vehicle verification of fan operation, over current protection and smart soft start for lower inrush spikes from the fan system just to name a few.
PLEASE NOTE THE FOLLOWING: The FAN-PWM-V3 is not intended for use with fans that draw more current than 30amps continuously. This includes (but not limited to) SPAL extreme performance fans, Ford Taurus fans and Mark VIII fans. THE SPAL FAN-PWM-V3 IS INTENDED TO BE ONLY USED WITH SPAL FANS
This unit does not come with a temp sensor if you need one you will also need part number FAN-PWM-TS
Ok. now that you have all that...it does come with optional temp sender if you wanted to use it. Comes with everything pictured. Keep in mind that this is used so the wires in the wiring harness will be slightly shorter than a new one. These go for around $115.00 plus and extra $20.00 for the temp sender new. Asking $65.00 plus shipping.
