Notices
Go Kart and 2001 Dodge Ram 4x4 1500 5.9 ecsb
Old Jan 9, 2012 | 05:22 PM
Overstreet's Avatar
Overstreet
Default Go Kart and 2001 Dodge Ram 4x4 1500 5.9 ecsb
Here is my project dodge Trying to move up to the oil burners
This is a 2001 Dodge ram 1500 4x4 Sport Model Quad Cab
Clean title in hand
Automatic, 2 Wheel ABS, airbags, power door locks, power drivers seat, Overdrive tow Package Chrome wheels
Has the trip computer
Motor: 360 V8 5.9 rebuilt with some performance modifications
Color Scheme Monster Green and black.
Rebuild included
New Rings
New Cam Bearings
New Main Bearings
New Freeze Plugs
New Roller Lifters
New Spark Plugs
New Cylinder heads that flow better and have stainless steel valves they flow almost as good as edelbrock aluminum heads
Harland Sharp Roller Rockers 1.7:1 Ratio
ARP Rod Bolts
ARP Main Bolts
Hot Tanked block
Line Honed
Standard size Pistons
Standard size Rod bearings
Standard size Main Bearings
High Volume Oil Pump
High Volume Water Pump
Hughes Plenum Intake fix
Msd Ignition Coil
All new sensors
8mm spark plug wires
180 thermostat and 192 thermostat
depending if you get a tuner by hemifever.
New fan clutch
Replaced most of the hardware on the engine
new air filter
all new sensors
all new gaskets
Magnetic drain plug that can hold wrenches with
Oil changed about 3 or 4 times already
have spare parts
Comes with a Joe Gibbs racing hot rod oil which is valued at 120 dollars have a couple filters as well.
Other things I have done to this truck is
A new ac evaporator and accumulator
New Dash because the ones that left the factory and all of these did not have Ultraviolet protective coating which the new one does.
New Heater Core
New belts
New distributor cap and rotor brass heavy duty version
rubber coated the front frame rails wheel wells fire wall and radiator support with por 15 underneath
Stereo: aftermarket sony head unit.
rebuilt transfer case
Exhaust: Pacesetter Shorty headers, new catalytic, new o2 sensors, Flow master dumped at the rear very good sound.
Transmission shifts good Truck runs strong
Just passed california smog legally and new registration
The Cons:
Have to recharge the ac systems very simple
Needs new tires but doesn't matter if you are going to lift it
a little rust on truck quick fix with por15 and bed-liner on rockers
Needs a transfercase vac switch
This is a very good deal and really awesome truck It has also been debaged I have way over 6500 in it. Only reason for selling is that I am buying a cummins
I am probably forgetting so much.
I also Have a HAASE Race Kart asking price is 1500
Needs a new front bumper
Rebuilt the carb new brakes stainless lines
comes with starter and kart stand
Old Jan 9, 2012 | 05:23 PM
Overstreet's Avatar
Overstreet
Sorry Asking price on the Dodge is 6500
Old Jan 9, 2012 | 11:13 PM
Overstreet's Avatar
Overstreet
6000 obo
Old Jan 10, 2012 | 05:41 PM
Overstreet's Avatar
Overstreet
anyone?
Old Jan 12, 2012 | 10:04 PM
Hylander7's Avatar
Hylander7
How many miles on the truck
Old Jan 13, 2012 | 06:09 PM
Overstreet's Avatar
Overstreet
224823 exact
Engine has about 1k
