1999 Dodge Ram 4X4 sport quad cab 360 , auto $2900
Red quad cab with grey interior. Has standard options, pw/pl/ps/pm, rear slider, bedliner, a/c, cruise, tilt. 171k. Has typical ram rust, dented passenger door (functions fine), needs a cleaning.
I have replaced the plenum plate with an aluminum one and also put shorter bolts in so it shouldnt have that gasket blow out like OEM plates do. I also replaced the wires, plugs, IAC, trans sensor, trans solenoid. Muffler was chopped (no its not loud).
Problem that Im having is that when I start out it bogs down and then she goes down the road. seems to start out in 2nd gear. Drives at 60pmh just fine it just seems to not have the SNAP like my other Rams. If you put it in reverse she'll spin the tire like its nothing.
I bought the IAC, sensor, solenoid at the dealer and the plugs/wires, thermostat at autozone. Plenum plate was custom made (CNC) so I have stuck a few bucks into her.
Brakes are fine, tires are fine, has typical dodge rust. Great winter work/winter truck.
$2900
pm me for pics
I tried adding pics but they are to big apparently.
$2900
pm me for pics
You can either reduce your pic size in Paint, or use a phot hosting site such as photobucket. If you have a craigslist ad locally, you can actually left click on your pics you uploaded there and do a copy/past on the pics and put them in your thread here. it's basically using their site for a hosting site..haha
Also, please read the Rules. No direct links to local sites and you need to remove your number and use the PM services to give that info out. Thanks and good luck
ahh didnt know about the phone number. kinda odd that ya cant have that in there seeing its personal info so its not like someone is hiding.
thanks for the info on the pics. Ill see if i can add them.
jeff
USMC
jeff
USMC
