Hey guys/gals I have an electric fan set-up for sale. The Fan is from a Ford Taurus and has two settings for the fan speed Lo/High. This fan will come complete with the fan of course, the adjustable thermostat, and all fuses and relays. I will also include all of the wiring that I had used to wire it to my truck that you can choose to replace with your own wiring if you'd like. This is an easy way to buy it all together in stead of having to piece it all together yourself. I have done all of the work for you.
I had this fan on my truck for about 8 months and it worked flawlessly but I have recently purchased a Toy Hauler and just like the piece of mind of the clutch fan as opposed to an electric fan.
I am not railing against the Ford Taurus/Mark fans at all, however, if you do use one, make sure you have a nice alternator. These things pull a lot of amps, over 100A at fan startup, IIRC.
Shipping to 24236 would be $24, but twothousand6 just PMed me that he still wanted it so I will give him first shot. If he decides otherwise then I will consider others.
