taken out with 120000. trans is in perfect shape and shifted beatifuly. engine could use to be gone though it started buring oil but there are many parts that can be used on it. it did run fine besides the oil burning. (about a quart every tank of gas) wll seperate. also have radiator for a manual trans (no cooler in it) only reason its being sold is because i swapped a 4bt cummins and do not need this gasoline burning peice of metal any more
You're in Indiana; if you were closer I'd really be up for the tranny. Actually, I don't know if I'm more interested in the tranny or the 4BT swap...as I have considered that.
