FS: 2.5" Race Ready Electronic Exhaust Cut-outs "Like New"
Like the title says, I'm selling a pair of 2.5" Race Ready (referred to as the best) Electronic Exhaust Cut-outs w/ stainless steel y-pipes. Install is a breeze, cut, slip-fit, clamp, and you're done! Work perfectly! Seal great w/ no leaks at all. A true head-turner, however my wife wasn't a fan! Retail: $504.99 only used for 2K miles and have them priced to sell fast! $299.00 shipped!
Eliminate Bolting and Unbolting Your Exhaust at the Race Track
Go from open to closed to anywhere in between with the flip of a switch. Race Ready Performance Kits include cutout valve(s), wiring harness, and hardware. JEGS Easy Kits additionally include cutouts.
Cutout Valve Features
6061-T6 billet aluminum housing machined down to .600"
CNC-machined housing ensures positive seal to Y-pipe
Extra thick gasket seals better and protects against heat
High-temperature O-ring strengthens seal
Built-in thermal protection device helps prevent motor overload
Bull nose butterfly secures matching Bull nose seat
Double-sealed 303 stainless steel butterfly = no leaks
Stainless steel shafts, coupler, and hardware
Proven, dependable gear reduction drive motor
Slotted bolt holes for mounting flexibility
Harness Features
Weather-tight connectors
Built-in, quick-blow 3 amp fuse
Heavy-duty, heat-resistant 16-gauge wire
Positive and negative leads labeled for easy installation
JEGS EZ Complete Kits are designed by JEGS professionals so you get all the parts you need.
For 2.5" dual exhaust, each kit includes:
Cutout Valves
Wiring Harness
Exhaust Cutouts
Hardware
[IMG]
[/IMG]
[IMG]
[/IMG]
Harness Features
Cutout Valves
Wiring Harness
Exhaust Cutouts
Hardware
[IMG]
[/IMG][IMG]
[/IMG]
