Notices
05 Dakota SLT Quad Cab 4x4 only 43k
Old Oct 21, 2012 | 04:56 PM
CrewKota's Avatar
CrewKota
Default 05 Dakota SLT Quad Cab 4x4 only 43k
This is a very nice, clean truck with the 4.7l V8 and auto. At 40k I did new struts, shocks, lower ball joints, and sway bar end links. At 35k it got new tires and brakes. We just got a new SUV and I have a company truck so I don't need my truck any more. This truck just sits in the garage so it must go. Asking $13,900. Located in upstate NY. For pictures check out my craigslist add. Thanks for looking.
http://albany.craigslist.org/cto/3352989526.html
This is the Build list from Dodge.
According to our records, your 2005 Dodge Dakota was equipped from the
factory with the following:
Sales Code Description
*P9 Cloth 40/20/40 Split Bench Seat
-D5 Med Slate Gray
ADJP Heavy Duty Service Group
AFHP Interior Convenience Group
AHC Trailer Tow Group
AJBP Security Group
AJKS Convenience Group
AJPS Power Convenience Group
APAS Monotone Paint
A82P 4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BCSS Run Down Protection Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CBZS Prem Vinyl Door Trim w/Map Pocket
CDLP Manual Driver Lumbar Adjust
CFNS Rear 60/40 Folding Seat
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUNP Overhead Console
CUZP Center Armrest Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHTS Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GUNP Power 6X9 Multi-Func F/Away Mirrors
GXRP Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAAS Air Conditioning
I89S Route 89 - CSX, Selkirk, NY
JAAS Instrument Panel
JA2S Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
JPSP Power 6-Way Driver Seat
KRSS STRIPE/BADGE/MOLDING/COLOR
LACS Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LBCS Glove Box Lamp
LHES Rear Dome w/On/Off Switch Lamp
LMBS Halogen Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
LPSS CHMSL Lamp
LSAP Security Alarm
MBES Bright Rear Bumper
MB4S Dark Gray/Bright Front Fascia
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MUMS Dakota Badge
MUZS SLT Badge
NAS 50 State Emissions
NBKS EVAP Control System
NBQP Federal Tier 2, Bin 10A Emissions
NFBS 22 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NHJP Exterior Mirrors w/Heating Element
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
NZDS Next Generation Engine Controller
PR8 Deep Molten Red Pearl Coat
QR8S Deep Molten Red Pearl Coat
RCDS 4 Speakers
RDDS Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHCS Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXVP P265/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WDQP 16" Steel Spare Wheel
WD1S 16X8.0 Cast Aluminum Wheels
XBSS Pickup Box
XCAS Occupant Classification System
XDXS Scissor Type Jack
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XGDP Universal Garage Door Opener
XSLS Brake/Park Interlock
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email and have a wonderful day!
Sincerely,
Matt
Customer Service Representat
