Notices
1972 Dodge Dart Swinger 37xxx original miles
Old Nov 12, 2012 | 03:16 PM
ccndodgeforum's Avatar
ccndodgeforum
PLATINUM SPONSOR
Exclamation 1972 Dodge Dart Swinger 37xxx original miles
This is a 37xxx original mile, unmolested Dodge Dart Swinger that has had just 1 recent respray, & new vinyl top installed.
Car is registered in Maryland with a clear title.
The interior is all original, (except for new carpet) and is all numbers matching. There is a 1/2" vinyl split on the top corner of the drivers seat and a 1/2" crack on the very left side of the dash pad.
Car is optioned with light package including lighted cigarette ash tray, ignition key light, trunk light, map light & fender signal lights. Also has bumper guards, AM/FM Radio, 3 speed wipers with electric washers, 3speed heater, & more.
I installed reproduction fender wheel well trim.
The AM/FM factory radio is not original to the car, but I have the original that came with the car. I'm unsure if it works or not.
No A/C & the engine is a 225 slant six with 1 barrel carburetor.
This comes with 2 complete built sheets & original smog & owner manuals.
This could use a new exhaust system as it is original, but it is still intact.
The following is what was done before painting. Replaced lower front left fender with metal patch, repaired the front right & left front floor pans with metal. I didn't use repo pans, just metal pieces welded in place.
The back floors & trunk areas are good as is the frame rails and no work needs to be done.
There is still one rust hole that I located, and it is on the inside of the trunk lid as shown in the picture.
Other than that, I found no other rust through places.
The rest of the body panels are solid.
All the glass is good & even all the original rubber weather stripping through out is still pliable. Even the torsion bar boots are intact and soft.
I have replaced the heater box and heater core.
This still has the original belts, hoses etc. I even have the original spark plug wires & cap. I switch over to a Pertronix II ignition.
When I painted this, I only did the exterior & under the hood as the door jams & trunk area were still in good shape. I wanted to keep as much of the original paint as possible.
The outside original paint had faded & a few chips and dings and so that is why the respray. I used K2 Epoxy Primer & PPG base with clear coat. Hand color sanded and buffed. I have the paint code mix if needed.
About the original paint....According to the build sheets I found, it calls for code GY4 Gold, but was painted a Y2 Sun Fire Yellow.
I know for a fact that this is the original paint on the car.
Under the hood needs detailing as it is in original condition.
Has 4 new 205/70-14 Hankook tires and freshly painted rallies. Original whitewall spare is still in the trunk, but has been used.
The previous owner installed a new gas tank & sender.
Brakes are like new and stop like they are power brakes, but are manual drum.
The auto trans shifts nice and the engine runs great and makes that slight ticking solid lifter sound that comes from the slanties.
Both bumpers have been replated by Tri-City Plating, but not the bumper guards. The vinyl top is from Kee Auto Tops..
All electrical wiring is in tact and has never been cut on.
Everything works on this car & this has always been a non-smokers car. Cig. lighter & ash tray are new, never used.
I'm sure that there is other things I forgot to mention.
This is not a show piece but looks really nice & I've only driven this about 200 miles since buying it back in the late Spring this year (2012). The car is solid and drives great.
Here's the reason I'm selling.
I want a V8 car and I just can't bring myself to changing the originality of this car. I'll leave that "guilt" to the next owner.
I am the 3rd owner of the car, and YES, it was a "little old lady's" originally.
I'm pricing this at a reasonable $7800........Follow the link for 100+ pictures of the cars progress until finished.
I have all receipts of what has been done. I haven't added the prices up, but it's up there. Frankly, I don't want to know......
I also have a repro fender tag with all the correct codes
http://www.flickr.com/photos/69912981@N03/
I live in Maryland zip 21085, off interstate 95 about 25 miles north of Baltimore or 75 miles south of Phila, Pa.
It is up to the buyer to take care of the shipping & charges.
I also require a non refundable $200.00 deposit to Paypal & final payment to be made upon pickup or before shipping within 6 days.
Car is sold as is, no warranty.
http://www.collectorcarnation.com/Do...html?aid=32798
